Just to correct the pinout, it's positive to D14 and negative to D16
D14 is the IP+ signal from the LAF and D16 is the IP-, VS- signal from the LAF. Krousdb has it stated properly in another post. You're correct in stating that D18 is the output for the SIL (shift indicator light) I think I'm going to make a new post about the VX wiring. |
yay!
finally got it smogged, its only been 6 months. turned out, it needed a new cat. hopefully ill have a lean burn monitor hooked up soon and increase my milage. |
where can i buy a new Vx cat assembly besides the Honda stealership?
EBAY one from a 96-00 should still bolt up. You would just need to plug the lower O2 sensor bung (which any performance shop would have the plug)
Very sweet! Looking forward to watching your MPG skyrocket!
M |
