Re: My Honda CBF125 on 150mpg :)
Even so, i think a starter lasts 80, 90, 100 000km, less than that, the battery dies first, and the engine is up in a half of a second
check a little video i did: https://www.youtube.com/watch?v=PyUJpDsXSoI Yesterday i went with a friend of mine, and, of course, the mileage is certanily to forget :D went to highway totally at WOT, 8km, the sparkplug went to 200?C. Even so, hope i can do 1.50 on this tank |
Starter and starting gear are only meant to be used at start, not constantly moving as the wheels/tires. Personally, I'd consider chain/sprocket & gear box much more durable than starter gear, since much of the acceleration/deceleration is stressing on the drivetrain. Chain/sprocket are likely to be easier to replace, too. Quote:
The starting gear you talk is this?
https://articles.dashzracing.com/wp-c...h-Z-Racing.jpg mine doesnt have that, only have a electric starter. A chain, rear sprocket and a front sprocket costs 40, 50, 60€, and it lasts 30k 40k km, in normal driving mode. A electric start can be re-assembled, and the cost is near 60, 70, 80€, but lasts more than 80k km just a thought ;) |
Starter gear looks like this:
https://upload.ecvv.com/upload/Produc...2617423510.jpg It is internal to the engine, wear and tear of the starter gear is not visible, only audible when it is worn. Attached to the tip on the spindle of your starter the turns the crank of the engine. To replace a starter gear usually mean removing the starter from the engine.. If there is no starting gear on the spindle of the starter, like the image below: https://img.tootoo.com/mytootoo/uploa...2871db2a9e.jpg You need to replace the whole starter when the teeths are worn. |
Nice! Even so, the starting gear lasts tons of km if well lubed (hope it was well lubbed in the factory btw), but usually it lasts 100k km.
I have 12k km on mine, lets see how long the starter or battery "lives" :) Other thing i thought: starting the engine releasing the clutch with a gear on (4th or 5th gear), cause some heavy wear in the clutch also.. |
On durability of other parts: the first drive belt lasted 63k km for me, rear sprocket wore off at 82k (literally wore off, because the replacement I had ordered from ebay took half a year to arrive... I had to buy another one locally and it was twice as expensive, ~480USD). The starter is ok after 91k. And I had to replace the battery twice. The first one lasted 5 years, the second lasted 2... |
But, as i said, this bike doesnt have starting gear, so, i only have 2 options: electric start or release the clutch on 4th and 5th, and wake up the engine.
One day, im wondering in a project for my bike. Will consist in a belt drive, like this: https://image.streetchopperweb.com/f/...belt_drive.jpg Maybe the FE will be better, what you guys think? |
