As mentioned above the screw just adjusts the idle mixture. It will be almost not relevant to power, pinging, or heat. The engine might stumble at bit on a cold start. The questions you are expressing concern about relate to the main fuel circuit and this screw will have almost no effect to it.
[QUOTE=Fourthbean;64779]Thanks, any input I can get is great. I have a 1 barrel carb with only one adjusting screw, and then the idle speed screw. Would I be able to lean it out with that setup? I could lose quite a bit of power and still be ok. What kind of problems would come up by leaning out? Hot engine and pinging? QUOTE] |
I must be seeing things... 84.1 mpg !!
Ok, so after jonesing for an aero mod, I went with the piece of lawn edging protruding straight down from the bumper, and slapped a flat piece of ductwork metal over the remaining grill openings (and threw some black paint over it). I just fudged it on there with panhead screws into the plastic bumper, took like 5 minutes.
Even I am sceptical, I swear though that I found myself braking where I was lurching back and forth in my seat to get a few more inches out of a coast. Maybe there is an unintended HAI thing going on too. Maybe it's placebo? I'll take it all the same :) Trip home today: 84.1 mpg !! 29 mph avg 58 mph avg 2824 rpm max 211 degrees max water temp 85 degrees OAT |
Wow. Is this with the Metro? Photo!
Just as an FYI, on my quest for a 100+ mpg fill-up, I was seeing between 105-115 mpg on a trip to a cottage where my avg speed was about 22 mph with 100% P&G.
Today I did one leg of the run using only DWL and EOC where approaching turns & stops. Average speed was 28 mph, and mpg was 85. |
4 Attachment(s)
https://www.gassavers.org/attachment....1&d=1185235713 https://www.gassavers.org/attachment....1&d=1185235730 I think it'll be real tight when I cut a coil off of each corner. 85mpg with dwl, that pains me :) |
Niiiice! :thumbup::thumbup:
Please tell me you're thinking about doing some ABA on that. After reading Houston Bill's air dam/coastdown writeup, I was theorizing that our cars' aerodynamics had less to gain from the same mod, based on the smaller than expected 2.x% FE gain (@ about 85 km/h) seen in my full belly pan trial (which was only A-B, admittedly). Maybe my theory is bunk, and/or my understanding of the trade-offs between a smooth bottom vs. honking air dam is flawed. As for my DWL/EOC #'s, remember: no alternator, taller F.D. & XFi cam. |
Well to be fair, the lawn edging is much more pronounced on a metro, it looks like a thong on Bills ride :)
CO: is Hem & Haw one cat or two? :D
https://aycu40.webshots.com/image/236...8595671_rs.jpg |
