Got the EV-1 controller
Excellent. :thumbup:
Some more excellent controller news: I got the Cursit
Whoops, missed this...
could be useful for comparing the efficiency of the 2 electronic controllers.
Maybe you could modify the meter with a heated needle and then run some thermal paper past it while driving... j/k :D
But seriously, if you had a way to make periodic voltage readings with your laptop, you could effectively record the current at intervals by reading the voltage across the shunt (that's what the meter does). Depending on what other measurements you recorded at the same times, you could build some interesting data to play with (like vehicle speed, braking, battery voltage, SOC, etc). There must be a cornicopia of A-to-D devices you can plug into an RS232 port with which you can take voltage recordings. |
Good ideas. Something like this?
https://www.rentron.com/Volt-Meter.htm It would satisfy the nerd in me to drive both the cheapest AND most instrumented NEV in existence. |
Or a DMM with an RS232 output:
https://cgi.ebay.com/Mastech-PC-RS232...QQcmdZViewItem Too expensive for Project Forkenswift, but I didn't even know they existed until you suggested it. |
