1) In general synthetic oils run a little easier, and are a little more "slick" (then conventional oils) at the same oil weight. Both of these factors tend to cause a minor (maybe a few percentage points total) gain in FE over a conventional oil. OTOH while a few percentage points gain is apparently common in this area, some have reported no gain at all at this level. 2) IMHO you really should use premium oil filters with synthetic, as one of your biggest enemies (for both FE and the length of time the oil can safely be used) is dirt in the oil. So why put in expensive synthetic oil that can last a long time, and then cut that benefit short by conventional oil filtration? And again, good oil filtration will often make a little difference in FE, by lowering engine friction by dirt in the oil. 3) And its common (and fairly safe) for quality synthetics to go with a "cold weight" (1st number, before the "W") lower than the conventional oil. i.e. instead of using 10w30 oil (or 5w30 oil), you may instead use a 0w30 synthetic. This is safe because almost all oils are too thick when first starting out (i.e. the "cold" setting), but the lower first number is still less thick (when "cold") then the more conventional oil weights. And because of the quality ingredients used (in the synthetic oil mix), a good synthetic can have a wider temp range than a conventional oil and still be able to hold up to abuse. Which is why you might as well go with a "0w" oil (vs the 5w or 10w oils you are used to) if/when you switch to a synthetic (as doing so shouldn't harm your car any, and it will help FE a bit until the car gets up to temperature). 4) And some have even taken the fact that synthetics generally hold up better, to go with a lighter weight oil AT TEMPERATURE (to help FE even more). For example, my CRX was originally speced for 5w30 conventional oil. However, I currently run a mix of 0w30 and 0w20 synthetic in it. i.e. At temperature, I'm probably getting about a 23 weight synthetic, instead of the 30 weight my car calls for. This means I get slightly less friction (and therefore slightly better FE) after the engine warms up (over a normal 30 weight oil the car calls for). However, it also means that I risk having a "too thin" oil that isn't sufficiently doing the job and will therefore cause extra engine wear. In my case, I happen to think that the extra ability of the synthetic to not get thinner as it wears out (unlike conventional oils that do thin out as they wear out) keeps me sufficiently "safe" against problems. And I also monitor this issue (with oil analysis testing) occasionally (and so far so good). But keep in mind that (unlike lowing the 1st/cold number) lowering the 2nd/hot number is not without its risks (as it is possible to get an oil "too thin" for it to do its job in the engine)! But if you can safely lower this number, it will help a bit with FE. So yes, if/when you factor in the FE gains from all of the above, it might be possible for it to be as high as 20% gain. But in general the gain will be less than that. Which doesn't mean that switching to synthetic isn't a good idea, or that it won't help. It just might not help as much as that article suggests. Quote:
BUT, you will only really get long OCIs (Oil Change Intervals) if you combine quality synthetics with premium oil filtration. Because most oil filters on the market leave a LOT of dirt behind, and that dirt will kill your oil long before other factors. So if you really like the idea of 10,000+ mile oil changes, you really have to use both quality synthetic oil and quality filters. Quote:
i.e. Each oil change will be more costly, but you will need to do fewer of them, making the cost per mile (of the oil changes you need to do) less than the conventional oil (but more frequent oil changes) approach. So when deciding upon synthetic or not, you really have a "pay me now" (more expensive synthetic oil changes now), or "pay me later" (more total cost of conventional oil changes, due to more of them being needed) decision. Quote:
1) All oils work better in a cleaner engine, but this is especially true of synthetic oils. So I personally would first clean the engine using the Auto-RX product ( https://www.auto-rx.com/ ) as directed (and yes, you need to use conventional oil while doing auto-RX cleaning, as synthetic oil tends to interfere with the auto-rx cleaning process). NOTE: There are cheaper engine cleaning products on the market, but I like auto-RX because (unlike most other products) it cleans while maintaining lubrication (i.e. it's a much more "gentle" cleaning product, with much less risk of harming your engine while cleaning). 2) If your car calls for 5w30 oil, switch to the premium 0w30 oil (for both technical reasons, and personal experience, I'm most fond of Amsoil's synthetic, but then again I'm technically an Amsoil dealer so I'm not unbiased). 3) As to oil filters, get the best filtration on the market (to keep the dirt out), which for most vehicles seems to be Amsoil's EAO line of fully synthetic media oil filters (and no that's not just Amsoil hype, it's been independently tested by various folks). 4) Keep an eye on your oil levels, adding "make up oil" as needed. Since synthetic oil runs easier, you often lose oil quicker with synthetic, especially when you first switch over. Also, as you make your OCI (Oil Change Interval) longer, you have a longer period of time to lose oil (i.e. few cars lose enough oil over a 3000 mile oil change to cause harm to the engine, but most cars will lose enough oil over 10,000 miles to harm an engine). So keep a periodic eye on your car's dipstick, and make sure you keep the oil level up to where it needs to be (i.e. add "make up oil" as needed, to keep the oil level up). 5) And it wouldn't hurt to make the first couple oil changes (with full synthetic oil) shorter OCIs than you will eventually go with, to give the engine a chance to get used to the differences (in lubricating and cleaning properties) of the synthetic over the conventional oil you have been using. Because while synthetic is generally better (some in the industry debate if its enough better to justify the cost, but few argue that synthetic is an overall better oil), it is none-the-less "different" (in how it cleans and lubricates) as well. And since machinery can get somewhat used to the properties of the fluids you use, its helpful to stress things less hard during a "break in period" (in this case getting the engine used to the properties of the synthetic oil you use). Since almost all oils work best when "fresh" (first put in), the easiest way to accomplish this goal is simply to make the synthetic oil change intervals shorter at first (so as not to depend upon the full benefits of the synthetic, until the engine is used to that mix). For example, I might change out my 1st synthetic oil change at roughly the same mileage as conventional oil (i.e. the 3000-5000 mile range), boost up my 2nd synthetic oil change to maybe 7500 miles, and only go 10,000+ miles on the 3rd+ oil changes with a good synthetic. NOTE: I'm technically an Amsoil dealer (even though I'm currently buying more Amsoil stuff for myself, than I am for the few "customers" I have). However, (being a dealer) I would be happy to help Gassavers members with discounts (on Amsoil products). So give me a PM should you decide you want some Amsoil products (such as their synthetic oil or filters). |
-Jay |
Yes, the higher FE (and lower engine wear) from using a 0w oil only helps for a few minutes (i.e. once the oil and engine are up to temperature, its the "high number" that dominates the FE effects), But since we all have to start our cars sometimes (especially if you make a lot of short trips), we all do end up having some of our driving dominated by the "warm up period" (and therefore also dominated by the 1st/lower number of our engine oils). NOTE: With conventional oils, you have to be careful about going with a too wide viscosity range (difference between the 1st and 2nd numbers). This is because the traditional "viscosity modifiers" techniques used to get a wide temp range with conventional oils actually make the oils "weaker" (more likely to wear out quicker, especially when abused). So with a conventional oil, something like a 10w30 (20 point range) actually still makes a little sense (as it will stand up better than a 5w30 conventional, much less a 0w30 conventional if you even could find/purchase that). However, most synthetics aren't made using the traditional "viscosity modifiers" that conventional oils use (i.e. different techniques are generally used to make a wide viscosity range in a synthetic). As a result, many synthetics can have a much wider temp range and still hold up to a lot of abuse. And since a wider temp range in a synthetic doesn't typically pay the same "price" (of much quicker wearing out of the oils) that conventional oils suffer from, going with a quality 0w synthetic pretty much gives you all the gain with none of the down-sides (that a 0w conventional oil would have). BTW: The "holy grail" of multi-viscosity oils, is an oil that maintains the same thickness at any temperature it will be used under, and we aren't there yet. i.e. Even a quality 0w30 synthetic oil, while much less thick "when cold" than a 10w30 oil, is none-the-less still thicker cold than when it warms up to temperature. However, the research seems to be moving us in that direction. So eventually, we might end up (some day) getting an "oil" that is the same thickness at -30F that it is at 260F (or any temperature in between). And ideally, that sort of "constant thickness" oil (that runs the same no matter what the temperature is within its operating range) is what we ideally would like for an engine oil for our cars. Quote:
I used to change the filter every other time - they held less than a quart - I cranked the engine over a little when the drain plug was out to empty the filter a little. Cars alway rusted away before any engine failure occured and that was with 6-8k change intervals and oil filter every other change. Now I don't have to change it at all . . . seems really weird . . . the "oil" level also doesn't seem to be going down at all either. |
However, in our fleet we did re-use our Amsoil filters for 2 oil change cycles to see what harm would be involved. The vehicles used for this were the late 90s 5.7 Ltr. GM V-8 with over 100 K miles logged, mostly highway driving. To make a long story short. The process involved dumping the filters on 2 vehicles and leaving the 1/2 or so qt. of oil in the filter on 2 others. In all cases very little difference was seen in the used oil analysis between the 2 after 2 oil changes. On average the vehicles were hitting 20K miles before the filter was ditched. Much of the above was due to the synthetic filter used, which the current filter is far superior to what we were using a few years ago. Again, this was an experiment that yielded favorable results yet Honda and some others are now doing a similar procedure but not dumping the used oil from the filter. Again, just a "matter of fact". I am though doing a similar experiment on a car that has nearly 150 K miles by using an Amsoil EAO filter thru 3 cycles. We also pre-filled filters during services, used or new. This I still do on my personal equipment and it only makes sense. Many think it's a waste of time that I'll strongly disagree with. As per dumping fresh oil thru during a change, not enough exposure is given to flushing out internal passage ways and surface areas to make this of any benefit but to each their own. More info can be found on my home page about lubrication and I'll update as time allows. |
Going to 0W30 synthetic from 5W30 conventional oil was worth between 5 and 10% on Wile-E. I "only" used the cheap walmart/supertech/tech 2000 synthetic and discovered it was amazing stuff. I put 10,000 miles on the one change, and it looked, smelt, felt like I'd only just put it in, and through the whole change interval it maybe went down the stick an 1/8th ... and half of that useage was probably me wiping it off the stick every week :D
Synthetic is different than conventional oil in that it fails in the opposite manner. A 5W30 synth is a 30 weight oil with viscosity modifiers that make it runnier when cold. When those wear out, you've still got a 30 weight oil protecting your motor at high temps and rpms. In a conventional oil, a 5W30 is a 5 weight oil with viscosity modifiers that thicken the oil up when it's hot. So when those wear out, you're left with 5 weight oil when your engine is warm and needs the most protection. As regards power increases, and we may infer economy benefits, David Vizard, a well known author of performance books, says he dyno tested synthetics and conventional oils and various blends and discovered that all the power benefits are there with only 25% synthetic in the motor. So if you have a motor that uses or loses oil, and synth is too expensive to have to keep topping it up, you could try just a quart of synth in a change. (presuming your changes are about 4 quarts) Theoretically then, you'd see the same gains as running full synth. This may go for powertrain fluids as well., but remember a pan drop and fill only gets about 50% out and typical capacities are in the 2 gallon range, so you'd want 2 quarts of synth fluid in there. However, leaky smoky motors have a better option, "High Mileage" blend oils, these I have found, run very nicely and reduce smoking and burnoff significantly, you can cut your consumption to a quarter or less. They have seal conditioners also that really seal up. No "snake oil" I've found is even half as good as these oils. In fact most of those I have observed to sludge a motor up, the HM oils clean it!. These are also usually a synthetic blend, and will give you better fuel economy than sticking in 20W50 and 3 cans of thick goop to try and get your smoking or leakage under control. If you're just burning oil and not leaking any, then consumption is likely to slow a lot with a straight synth, because they resist burnoff a lot better. The detergent propertied in synth or HM oils may also unstick rings, which may be causing a smoking problem, whereas "snake oil" type stuff will just keep adding to the problem by building up the carbon trying to seal it that way. |
I bought a lifetime billet aluminum oil filter with stainless steel mesh and 1000psi bypass for my 3000gt vr4. Took out the synthetic oil and put in Shell Rotella 15-40. Was $8.88 at Walmart but is now $9.37 for 4 quarts. I can remove the filter and basket and clean it and reinstall it without any leakage. I do this about every 1000miles. Went from 4 lbs pressure to 16 lbs pressure with the new filter.
Paid $219.00 for it. I found it at a race shop in Huntington Beach that supports Bonnieville race cars. It works great. |
While going through college I worked at a gas station in ND. One really cold night a lady asked me to put some oil in her car for her. I grabbed the oil from her trunk and tried to poor it, but it wouldn't come out it was so thick! I ended up exchanging it for a warm one from inside.
I decided to do a test that night. I took a container of 5w30 quaker state and a quart of 5w30 mobil 1 and put them outside. After a while I checked them with our thermometer and they were both -15 degrees F. The quaker state was so think you couldn't get it out of the bottle (much like I had seen earlier). The Mobil 1 was thin enough that you could still get it to slosh in the can. Ever since then I have run Mobil 1 in all of my vehicles (without problems). I have watched it cure cold weather starting issues on lots of vehicles including cars, motorcycles and diesel trucks. I also had 2 early broncos. I had put Mobil 1 gear lube in one, and the other was dyno oil. At -10F I could easily push the one with Mobil 1, it took 2 people to move the other one. This was inside my storage shed on flat ground with the transfer cases in neutral, so the only appretiable difference was the gear lube. So, its not a bad idea to run synthetic oils all around, but there is an unquestionable gain to be had for those who live in the frozen north. Mr_C in MN |
-Jay |
