I also think that 1K is reasonable. for me, it would only take about 2 tanks to get that and depending on the time frame, about 2 weeks.
I drive too much. |
I would recommend changing the "Gasoline" category to "Automobile".
But we can't just call it "automobile" because that would be confusing with the Hybrid and Diesel categories... Maybe we could call then "Gas Autos" "Hybrid Autos" and "Diesel Autos" |
As soon as I have the ability I'll implement as much of this as I can.
Hi moderators!
Any news about a change in the 90-day top-ten calculation algorithm? About half a year ago some guy (TDI'er) made a single fill up, and since then he has been number one on the top-ten diesels! In my opinion it ruins the fight to be in the top-ten completely!!!!:mad: |
I actualy get a lil happy to see someone with same car as mine and see how there doing. |
Actually the current top-3 on the diesels has NOT entered a single fill up in the last 5-6 month!!!! |
Maybe we need a 120 day period between fill-up entries because we don't use fuel quickly enough? It takes a while to burn through 25+ gallons of fuel at 50 mpg, ya know.:p
My personal feeling is this... A 90 day average is just that. If you are only purchasing fuel once every 4 months, then when you fuel up you will be in the 90 day rankings for 90 days, then drop until you fuel again. If staying on the list is important then make sure you top off the tank every 90 days. I don't think that's too much to ask.
-Jay |
Well, if someone like that tops off every 90 days and gets smaller amounts, they will spend more miles dragging around more weight in fuel (which may matter more to highly efficient or insufficiently powered vehicles); and worse, they may not put in enough gas to qualify for the list, which shouldn't be based on 8 gallons in 90 days.
However, if you're driving so few miles (let's say 50mpg and a 14 gallon fill -- that's 700 miles, or under 8 miles per day) then your results are probably not meaningful to compare to those who drive ten times as much. |
