GasSavers_Otto |
03-20-2008 07:51 AM |
Why not use both alu. screen and coroplast?
The aluminum screen is cheap, fireproof, breathable, and apparently pretty easy to install. Does not rattle or boom like sheetmetal. So, use it around the hot spots like mufflers and exhaust pipes, to let hot air be drawn out by Venturi effect. Also, being a superb heat conductor, it will very efficiently dissipate heat from any point of contact with a muffler, etc.. Even though porous, the screen will still go a long way to reduce improve form drag, i.e., streamline or smoothly cover otherwise gross aerodynamic shapes such as leading edges of mufflers, etc.. Porsche uses perforated screen as an engine cover on its latest high performance mid-engine car, the Carrera GT.
Coroplast everywhere else practicable.
