I've noticed that our F150 simply will not engage the lockup in topgear until it heats up which is typically a good five minutes or more down the road. During this time, economy drops from about 18 mpg to 16. I can only guess that the ATF viscosity is just too high to engage the lockup until warm and that extra 2 mpg is essentially diverted to heat it up. So the question is, will synthetic ATF improve the time lag until lockup is possible?
When I did my engine swap i didn't reconnect the tranny oil line to the radiator. I can't because I lost the fitting
The tranny doesn't ever warm up and so for some reason it was holding it in low gears. OD doesnt enguage till 60 MPH... |
What's short shifting?
A couple posts in this thread mentioned it. |
Short shifting just means upshifting at low RPM to maintain a higher load under acceleration. Theoretically, it permits the driver to keep the engine near the BSFC happy zone longer.
It's the opposite of what an automatic will do when you stick your foot in it - since the AT shifts based on load, it will hold a lower gear longer (or even downshift) for better accel. |
OK. I've been doing what I can to keep my AT at lower rpms. Basically, a light foot.
I also slacked off the adjustment on the kickdown cable a couple turns. So it doesn't jump down a gear at the drop of a hat. |
The cable adjustment should help, yes. I think RH77 played with that on his Acura (unexpected results?) - he may have more to offer.
Experiments for me showed that a loose cable gives the tranny less pressure to shift, and could slip and wear prematurely -- also it took further up the RPM band to decide to shift. I have mine tighter-than-stock, and I'm getting great FE results, although with firmer shifts. Does your car have a torque converter? RH77 |
Slackening off, is, I think he means, adjusting it so that it tugs less on the transmission, so that it registers less throttle input and shifts sooner/doesn't kick down as quickly.
Adjustment Area
I tightened the cable adjuster so that it pulls more on the transmission cable with more throttle input. With the OBD-II feedback loop, it takes the TPS reading and communicates with the TCU. The result is full-TC lockup at exactly 35 mph, whereas stock is closer to 40. A pressure sensor in the transmission will help decide when to make the shift, and with the cable tighter, it upshifts sooner. Downshifts are based primarily on Load and TPS input (generally 45%+ TPS, with 70%+ loads) or, of course, vehicle speed as it slows. As it stands, TC lockup will hold with the added pressure from the cable actuation over the input from the TPS/VSS -> TCU circuit. Long story short, a shop manual will translate how the transmission "thinks", and what modifications are required to excercise some control over the slushbox. RH77 |
