:thumbup: :eek: I just added more pictures and information that I believe will be extremely helpful to current/future VX owners, or for anyone running Versions 1.0 thru 1.5 of the DIY WB O2 kits from Tech Edge. It's a lot of reading but it's worth it. Just PM me or post here any questions you might have since this has kind of turned into the end-all VX information thread.
would something like this work to monitor the LAF? its nice, small, and backlit. it displays +/- polarity as well.
https://cgi.ebay.com/20VDC-BLUE-LED-A...QQcmdZViewItem |
It looks like it would work as a monitor.
There are two ways of monitoring the LAF: Positive lead of the DMM/DVM to pin D14 (orange with blue stripe) Negative lead to pin D16 (blue with green stripe wire) for a reading of -1.xVolts to +.XVolts. + being in lean burn mode. OR Positive lead to D14 Negative lead to chassis ground or D22 (sensor ground) for a reading from +0.xV to +3.1V (lean burn is when readings are above 2.7V) |
Added more info about Aero parts today.
Are the ECU connector pins the same on the later HX? Are the O2 sensors the same (L1H1)? Thanks
And the pinouts of the ECU on the HX are different as it is an OBD2 vehicle. |
If you're just trying to monitor the AFR with a wideband, see the link below. The LC-1 with the Bosch sensor is $199. It allows both an analog output (monitor with DMM) or a serial output so you could datalog your AFR's.
https://www.diyautotune.com/catalog/w...d327536136be3b |
anyone know where I can get a cheap L2H2? Would a L1H1 work?--Just wondering. Does the Lean Burn on the HX function with similar voltage outputs? Thanks for everything.
Your best bet would be to check Ebay for the L2H2 or Oxygen Sensor Warehouse
L1H1 is more expensive than the L2H2 plus it's best to stick with what your ECU is expecting for readings. They have slightly different output curves if memory serves me correctly. UPDATE! I have added info for rust repair panels. |
