53 mpg @ 65-75 is very promising. I'd even say: "holy lean burn, Batman!"
You're going to enjoy it. (I'm nursing a simmering case of VX envy, if you haven't noticed yet.) |
Very Nice! By those stats that was money well spent! |
Congrats Robbie! 53 MPG at 75MPH without drafting sounds about right. I get 60-65 at 60MPH and 70 MPG at 55 MPH without drafting.
Hook up a DMM to D16 and D18. When the O2 is cold, you will see -.0.77V. If you see +0.77 then switch the leads. You will see +0.40 during lean burn cruising. 0.20 at idle. You also might consider buying a SuperMID. |
thanks. the DMM will be one of the first things i do. i had the A/C on for about 250 of the 450 miles as well. im sure i could get some good numbers with the a/c off and going a little slower.
anyone have any useful tips for smogging this thing? i know the out-of-ca cars put out more Nox, do i have to make sure i tell the smog tech its out of state? any info would be great, i cant stand going all the way over the to smog check place and then going home with a FAILED cert.
What's amazing about the VX is not only the fuel economy it can manage but also 0-60 mph in ~10 seconds. Definately a good platform to build a fuel miser from. Give it some aeromods, LRR tires and all the rest, and youll be well on your way.
It's not even that aerodynamic of a car. Imagine a small, aerodynamic sports car that used that engine. Say, ~1,200 pounds, a .20 Cd, and 15 square foot frontal area... |
I want a VX so bad. In my car I can only manage low 40's if I try.
My car gets over 50 on the freeway easily. The probably is I have a guilty conscience and I speed up for other drivers.
sorry to resurect an old post, but when checking the o2 via d16 and d18, should both read the same number? the d16 goes directly to the o2 but the d18 goes to the shift indicator light according to the haynes. am i supposed to be check any of the other 5 wires coming from the o2? i have a hope that my o2 sensor is bad but i just want to be sure before i spend 300$ on a new one
