Re: Breaking news! Chevy volt technically driven by gas engine!
As I understand, it will only run the gas engine when it's being driven. Parking in a garage ought to be fine.
It won't be entirely wasted. It will surely offset some battery usage when it runs. |
I think I use 9 gallons a year just revving the engine at stop lights to scare the **** out of pedestrians.
Well it looks like I will be able to test drive the Volt sometime in December.
Two of my customers bought Volts and have already put in 240v plug in stations at home and their work. The other thing I can't wait to see is that both of these will be tested in a mountain terrain area. |
One thing I don't understand is how inefficient this car is when the ICE is enabled. Its truly pathetic!!! Is it the engine... drive train or something else that makes this thing a fuel hog!!!
Its great for a short commute while in electric mode but if you need to go on longer trip more then 50 miles you might as well take another vehicle and leave this over priced inefficient car at home.:thumbdown: |
Where are you getting your 'inefficient fuel hog' data exactly? Citation?
1) Drive it like you stole it pedal to the metal and see how it would do in the worst possible case scenario. 2) Drive it normally. |
