4 valve misconceptions
How about comparing the Nissan VQ35 engine with the Pontiac 3.6L engine. Nissan 3.5L DOHC 24-valve makes 258 ftlbs at 4400 and 270 HP at 6000 Altima is rated at 19/26 FWD with CVT and weighs 3400 lbs Pontiac 3.6L OHV 12-valve makes 251ftlbs at 3200 and 252 HP at 6300 G6 is rated at 17/26 FWD with 4-speed auto and weighs 3300 lbs They aren't far off from each other. The -2 MPG in the Pontiac can be easily attributed to the 4-speed vs CVT. The Pontiac has 7 less ftlbs of torque but makes it where someone can actually use it without having to rev the engine up. A lot like the G8(my fav!). My personal favorite: Pontiac 3.6L OHV 12-valve makes 248 ftlbs at 2100 and 256 HP at 6300 G8 is rated at 17/25 RWD with 5-speed auto and weighs 3885 lbs Lets see your DOHC engine make peak(or any) torque that low. That 3.6L G8 engine has a 4200 rpm powerband (the Altima's is 1600 rpm). That's HUGE! Plus, it only gets -2 city and -1 highway and weighs about 500 pounds more than the Altima. The only reason I didn't use it in the comparison is because the G6 is more apples to apples as far as cars are concerned. |
Secondly, I know I may be nitpicking somewhat. But you are comparing a 3.5l motor with a 3.6l motor. This may not seem like alot, and it isn't. But torque is VERY heavily tied into engine displacement. In fact, you will find that most engines produce a peak torque (in ft-lb) that numerically is within plus or minus 20% of the cubic inch displacement (consider a few examles for yourself). So a displacement difference of 100cc (assuming that this is truly the difference in displacement of the motors) will, all other factors being equal, give the larger engine a 6ft-lb advantage. Something to consider. |
Hi swng, that two-speed Toyota transmission was probably the 'Toyoglide'. I owned a 1978 Civic with a similar two-speed and it was OK round town but at speeds more than 50mph it really became a buzz-box.
Do Not Buy That Car, They Are Hsit
We were the original owner of this 1994 3-speed automatic Corrola base model. Very poor drivetrains,underpowered and overworked. Its wanted a fourth gear so bady it screamed out of the engine bay to 'please shift me!" but there was nothing there. There was a different engine and tranny in the other model for that year that had more torque and more horsepower and got better mileage because it could relax the engine at highway speeds. The model you are looking at is horribly unreliable and breakdown prone. The kind of crap that you'd expect from a 70's era USA car maker. Shocks were totally gone at 80k miles, Alternator, starter, constant leaks, ate oil, transmission fried at 130k. Buzzes and rattles throughout the interior. The car was maintained on the maintenance schedule and it literaly shakes itself apart. DO NOT BUY THIS PIECE OF CRAP !!! |
Blackhawk is a 3 speed auto. but it's a 97 tercel. but i have a scanguage. it's revving between 3000-3400 between 55-65mph. But i've notice i get super mpg's at 35-45 mph. on a flat road doing 45 i was getting 49.4 mpg. but driving 45 on the highway here is way too dangerest. plus KY gives a tickets for doing more then 8 mph below the posted speed limit.
Sounds like that gearing is ideal for city driving...
-Jay |
