51.15 mpg two way commute today . :) Grinning :) . 47.8 mpg Tank per SG.
Nice work Mn! Congrats.
Thanks Metro ! Looks like I'm about 1/2 way there lol - a 47 pales in comparison to the Elite in the Top 10 , but it does feel great none the less .
My goal is 50 ...now I'm seeing it *can* be done - I want more already ! |
Well, my #s aren't nearly as high, and I am not even the all that for my vehicle, but I just posted a 39 mpg tank! My best so far.
14 mpg improvement from the beginning of May to the end of June is nothing to scoff at ...and 4-0 is *right there* .
I had another 80+ day today.
1) 68.7-5.8 2) 84.5-9.6 3) 71.5-5.3 4) 107-6.2 5) 85.8-10.7 6) 87.1-9.1 7) 87.3-13.8 8) 87.8-4.9 9) 107-4.5 Average for today was 82.3. The tank is at 74.1 after 554.0 miles with 4 pips showing. |
Gassed up for 80.2mpg (708.2miles/8.83gal). This entire tank was interstate driving doing 60 to 65mph on I-26 running from SC up to Asheville, NC.
49.0 Mpg
EDIT : This result should be considered suspect because I used the IAT resistor mod (https://www.gassavers.org/showpost.ph...8&postcount=61) :(
Hello - NEW personal best today on the way home from work. Here's the info : MPG : 49.0 (old best was 48.1, so a 1.8% increase) Route : 105 East -> 710 North -> 10 East -> exit freeway -> North on Rosemead Miles : 36.4 MPH Avg : 43 MPH Max : 70 Net Elevation change : ~788 feet up (+210 on freeway, +578 on streets) Weather : 65.5+ degrees F, Clear, 73% Humidity, 56.5 degrees F Dew Point Time : ~9:22 PM to ~10:10 PM, ~48 minutes Hypothesis : Traffic was ok, but kind of fast for good MPG. I was at 53.1 MPG when I exited onto Rosemead, and I think that is my best to date. I tried the Saturn IAT resistor mod today. I used a 220 Ohm resistor that reports a steady 200 degrees F IAT to the ECU/PCM. Since we haven't hit hot dry August temperatures yet, the IAT mod could have made the difference. I do not plan to maintain this mod unless I can verify that I am still California emissions compliant. This is a test of the emergency MPG system. This is only a test. Another big change is the new tires. Calculations show that it should give me a 0.5 to 0.75 MPG jump, which is within the range of what happened tonight. However, since I went from "end of tread" tires to brand new tires, the jump may be greater than 1 MPG. If yes, then this would make the IAT mod moot. Quote:
59.6 Mpg
Hello - NEW personal best today on the way to work. Here's the info : MPG : 59.6 (old best was 58.6, so a 1.71% increase) Route : 10 West -> 710 South -> 105 West -> 405 South -> Exit Freeway Miles : 27.8 MPH Avg: 48 MPH Max : 64 RPM Max : 2637 Gallons : 0.5 IAT Reading : NA - Using 220 Ohm resistor to simulate 200 degrees F IAT. Net Elevation Change : ~210 feet drop Weather : 76.5 degrees F, Sunny, 50.5% Humidity, 55.0 degrees F Dew Point Time : ~11:00 AM to ~11:30 AM, ~30 minutes Recent Car Changes : New tires and 220 Ohm resistor simulating 200 degrees F IAT. Hypothesis : I think the tires are making the difference, but the % difference is too small to make a real conclusion. I don't think the IAT mod made any difference. The traffic was a little too pushy at the end, or I think I would have been able to hit 60 MPG. Oh well, something to shoot for next time :) . Quote:
