-   Electric and Solar powered (https://www.fuelly.com/forums/f18/)
-   -   Electric conversion: Project ForkenSwiift (https://www.fuelly.com/forums/f18/electric-conversion-project-forkenswiift-1605.html)
MetroMPG 09-09-2006 01:09 PM
Thanks Dan. Watch out for those armadillos - I hear they increase rolling resistance :D
I'll get to see, um... more whales, seals and porpoises than you!
JanGeo 10-02-2006 03:47 PM
WOW I know a lot of guy in Power-Assist that will be happy to hear that law being passed.
MetroMPG 10-02-2006 05:09 PM
The only downside is they're calling it a "pilot project". So it's open to review sometime down the road. Still, cool.
GasSavers_DaX 10-03-2006 04:52 AM
I love seeing updates on this Darin!
Matt Timion 10-05-2006 05:24 PM
Originally Posted by MetroMPG
Took the parts to the machinist today. May end up modifying the motor shaft rather than trying to incorporate the existing splined pump shaft into the coupler design.
The machinist hemmed and hawed about the pump shaft until I suggested we could change the motor shaft.
So maybe next week something will happen... One thing I know will happen is the total $ investment in the project will probably have increased by about 30-40% by the time we get out of there :D
This is an exciting part of the process... where all of the custom works really comes into play.
I was just thinking how useful this thread is going to be to a ton of people when you're done.
MetroMPG 11-01-2006 05:47 PM
Update-o-rama!
Picked up the motor & tranny fro
MetroMPG 11-04-2006 05:59 PM
Pics of the mystery parts I've been talking about...
MetroMPG 11-05-2006 03:15 PM
Well, the blue Forke
The Toecutter 11-05-2006 10:30 PM
Block heaters can make decent outlets to use to your advantage when you need a charge.
You should seriously consider aeromods to this thing to increase top speed and extend range.
Silveredwings 11-06-2006 11:48 AM
Originally Posted by theclencher
What is nominal shaft diameter of the armature? I would compare the adapter's diameter to that, not the tranny's. If it is smaller it could be a potential weak point... but really, how much torque is it going to be called upon to transfer?
It's hard to say because the emotor can put out so much instantaneous torque from a start that it can easily chew things up. Metro, maybe you should put some kind of damping circuit on the accelerator potentiometer to limit sudden increases (if your controller doesn't have this already). That "soft coupler" you have is very clever.
