I was thinking that the best way to figure out what's going on is with live sensor data.
When a modern engine is idling high, for example when it's cold, how does it do that? Does the throttle get opened, or does it run rich, or something else? I suspect high idle in neutral at speed would be done the same way. What sensor should I watch? I'll order my ELM327 tonight, I think... |
I know on my protege I have about a dozen ecu "triggers" that tell the ecu to enrichen the mix, ie more fuel. This bumps the idle up slightly. Headlights, rear defog, rad and interior fan, wipers, etc are all triggers. I would assume most vehicles have some sort of trigger. At idle the Protege is nearly 15:1 for mix, but if I kick a few of these triggers on it increases to about 13.7:1. Small increase, more fuel, bigger bang, more air drawn in, idle increases to compensate against the alternators increased drag. Currently all these triggers are just bare wires, and I can increase my rpm manually without the alternator drag.
Okay, small sidetrack there. But yes, the ecu injects more fuel, leaves the injector open longer, wala, higher idle/rpms. You should be able to see it with your fuel rate monitor. You should see a higher value when you first fire it up in the morning. |
You didn't read what I said did you? |
It should suffice to monitor O2 sensor readings via OBDII; I'd compare triggered fast idle and normal low idle to the neutral-at-speed fast idle. |
Put a car up on jack stands and start it. In N the wheels will start turning. Damn. How does that work? |
input shaft spins, fluids move, primary and secondary shafts move. When loaded (ie on level ground) the car doesn't move, but in the air, the friction is close to nothing, therefore shafts spin. Does this mean there is no neutral? no, it just means the tranny is built solid and with tight tolerances. Neutral still exists. The engine has no direct mechanical connection with the tires.
Ok, so the question is...is that fluid connection enough to increase engine RPM by 10% when the driveshaft is spinning at highway speed?
