Hello -
Ok, I found the document, so it was part of the conference : SAE Technical Papers Title: Improving Automotive Fuel Efficiency with Deturbulator Tape Document Number: 2007-01-3458 https://www.sae.org/technical/papers/2007-01-3458 CarloSW2 |
Seems to be that traditional glider turbulator tapes are raised vinyl sawtooth tape -- with different lengths/frequencies of the sawtooth pattern. Sinha's turbulator tape looks to be more like a sandwich -- imagine duct tape with a thin plastic set of stand-offs. 1) Bottom layer's the adhesive portion to stick it to the vehicle / airfoil surface. 2) Then there's the "ridged substrate", a set of (equally spaced) standoffs above the adhesive layer. 3) Atop the ridges is a thin membrane -- probably made of mylar, or since the examples are sort of shiny... aluminum backed mylar? The height of the tape, top to bottom, according to the diagrams he's used in his SAE presentations, is only 50 to 100 micrometres (2 to 4 thousandths of an inch). Erm, I don't think it's much thicker than duct tape would be, really. Sounds a lot more like coroplast scaled down, with saran-wrap on top instead of the hard plastic sheet the one side. Instead of presenting a "rough" surface, like the sawtooth tapes, or say, sandpaper grit-side-up, the design Sinha's testing seems to vibrate the membrane on top to perturb airflow and/or dampen and remove energy from turbulant flows to make them more calm and laminar, instead of strong, rolling eddies. |
after a brief look trought the first document cfg83 posted one thing struck me.
i've been wondering for a while if the windshield to roof transition is't an area that could use more attentiom, and this seems to confirm it somewhat. afterall what good it it to worry about attachement of airflow at the end of the car if it aleady gets detatched at the beginning of the roof. so these turbulators or even vortex generators might work there. i wich i had a moonroof, that would make tuft testing quite easy. |
2 Attachment(s)
Hello -
Here's a pic from the report to illustrate ChrstphrR's commentary : https://www.sinhatech.com/SAE-APAC-20...08-06-2007.pdf Attachment 1072 CarloSW2 |
lunarhighway -
CarloSW2 |
than again my aerodynamic understanding is rather inclompete so i might be wrong about this |
2 Attachment(s)
Hello -
What I find interesting is that instead of the form of the car being "static" in relation to the air resistance, it is instead interacting with the airflow and modifying the turbulence dynamically. If this was designed for airplanes that normally operate at air speed X, would a different version for cars (aka modifying the dimensions of the elements of the tape) work better for cars driving at highways speeds around 65 MPH? Orrrrrrrrrrr, because the membrane is acting dynamically, maybe it operates over a range of speed? Also, gliders are going closer to car speeds, right?!?!?!? ... time passes ... Answering my own question with this picture : https://www.sinhatech.com/SAE-APAC-20...08-06-2007.pdf - Page 12 Attachment 1074 From the above, it seems that the glider's airspeed is comparable with cars. I highlighted 51.8 MPH as the "sweet spot", at least based on the above test. On the ground this sweet spot would change (right?!?!?!). If it did need to be modified, then I think it would need to be modified for even greater top speeds (I was originally thinking the opposite). Knots to MPH conversion references : Convert Knots to Miles Per Hour https://www.flightsimaviation.com/rul..._per_Hour.html Conversion table for knots to miles per hour https://www.flightsimaviation.com/rul..._per_Hour.html CarloSW2 |
Looks like yet another gimmick to me. |
In the photo of the Escalade model in the wind tunnel (click on the photo for a larger image) we can see the deturbulator strip across the front of the roof just aft of the windshield. Do you think the tape going across the hood to secure the model has any measureable effect on the aero?
We've seen photos of vortex generators on the sides of vehicles; might deturbulator strips be beneficial there, too? If so, where on the sides do you think would be most effective? |
If I understand right, these tapes are ridged to vibrate with the wind pressure...
I suggest sport tape for experiments: It is fabric, very cheap and comes off easily. Duct tape is just slick. I don't have time for these experiments, as I will first pursue other options. |
