-   -   tire tread type and FE (https://www.fuelly.com/forums/f8/tire-tread-type-and-fe-6644.html)
rh77 11-08-2007 05:34 PM
Originally Posted by theclencher (Post 80950)
no need to duck
just prove where airtabs work and i'll set my rock down
Yah, I'm a data guy too. The Scientific Method is too powerful to ignore.
Now, for the Acetone -- the application varies so much to the point of inconsistency. I'm not throwing rocks, just stating my case.
RH77
Danronian 11-08-2007 08:07 PM
Back on topic a little...
Where would someone find a list of the rolling resistance of tires or a list of Low Rolling Resistance (LRR) tires?
ajohnmeyer 11-08-2007 08:13 PM
Here's the Green Seal LRR tire compro test-thingie from a few years back.
it's a PDF file.
Danronian 11-08-2007 08:46 PM
Thanks a lot. Interesting source.
theclencher 11-08-2007 09:09 PM
https://forums.tdiclub.com/showthread...=147718&page=4
discuss
shun
dletm08 11-09-2007 04:45 PM
Thanks for everyones input. Hopefully I will sell the thing before it needs new tires. I only drive it about 3,000 miles a year, so it is a good bet, but if not, I'll be going with a highway tread for sure.
rh77 11-09-2007 06:06 PM
Boeing 757-200
I had a nice 3-hour flight today with full view of airtabs in action.
For those aviation fans our there, here's the aircraft: the Boeing 757-200, 5500-Series on NWA. (757-251)
https://pic16.picturetrail.com/VOL698.../287638865.jpg
Courtesy Airliners.Net
As I looked down the wing at these 14 items, it became perfectly clear. Unless you plan on using the top of your vehicle as an airfoil, and you're concerned about losing lift when going up hill, then forget about it.
The link that Treb' posted made it plain as day. In aircraft, it holds the air to the top of the wing, using vertices -- shaking up the airflow so it "sticks" to the top, and the wing doesn't loose lift when tilted upward.
What advantage does this have in a car? It shakes up the air, and creates a disturbance at the rear of the vehicle -- an unwanted side effect of the average vehicle anyway. Mitsubishi did a test of it on the Evo-9, and came to an interesting conclusion (you'll still find it on the car, though).
Mitsubishi Test Article
If I'm missing something, let me know...
RH77
