exactly. you use it when pre-ignition is present, or there is a great fear of it.
i.e. taking your force induced (turbocharged, supercharged, or n2o injected) engine to the limits (or just a stupidly high effective compression normally aspirated engine) without using expencive $4-7/gallon, limited supply of race gas (commonly avalible in 100-102-105-110-115-120 octane), or ethanol. ethanol i hate. it's completely communist. wich ever moron dreampt that up should be shot. you're correct in that ethanol can also solve pre-ignition problems. It may have only a small portion of energy gasoline has, but it's only real upside is that it equates to about 105-115octane gasoline all things depending... so while it's completely crappy to run an engine off of, with foced induction it's atleast on equal terms with gasoline in power production once you push it beyond the normal pre-ignition limit of common 93-94 octane pump gas |
So, like I asked before, how exactly does reasonable water injection reduce power during normal driving conditions? |
Bottom line: It can't make more power vs. a proper tune on gasoline alone, but it can reduce it - depending on what compensations you or the motor fail to make. |
Let me know when it burns. :p |
P.S. There is a very specific reason why water injection alone doesn't improve eff, but I haven't seen anyone mention it so far. :p |
Have you all read about the 6 cycle engine where water is put into the cylinder which turns into steam and creates an extra power stroke?
I am curious if there would be a small affect of this with putting water in on the normal intake stroke causing any steam buildup helping economy. Or maybe cooling down the cylinder while you are trying to create a big boom isn't good... |
Think about it guys, if FE increases with humidity, couldn't you just put steam into the intake manifold? the steam could be obtained by wrapping copper tubing around the exhaust manifold. steam=water vapor, water vapor=more dense air, more dense air =better FE?
It sounds like you've just had one tank lower than the last which I woulnd't worry about. try some more consistent and controlled testing, don't go running off half cocked with ideas because something happened once.
The best use I've seen for water injection is cleaning engines (followed by an oil change (water blows by a lot) and high power engines as an anti-detonant. like everything else in the engine, it does have to be tuned...extensively as the gas. it's effects will vary with rpm, charge quantity (turbo/superchaging), charge temp, mixture, etc. My own dabbling around with it has shown higher octane does not benefit an engine not tuned to use it. I get better power, response, mpg using premium because I have my ignition advanced nicely. the advance gives the goodies, octane allows it to happen. Just like WI...if everythings running fine, it wont help |
What I meant about putting steam into the air intake isn't really to add water, but to add water vapor, to make the air more dense, giving more "oomph".
Is't steam heat? hmmm..
