https://www.spiralturbobaffles.com/semiinfo.html
https://www.aeroexhaust.com/ https://www.bladeyourride.com/ At ATDS the Blade was tested on a 2004 Honda Civic using the EPA 511 Testing Protocol, which is a combination of the EPA's FTP–75, and Highway Fuel Economy Tests. EPA 511 includes the measurement of three baselines and three tests. The EPA 511 is considered statistically valid. https://www.bladeyourride.com/Blade-511-Results.html The same 2004 Honda Civic was road tested for 6-months and the average gas mileage increase has been aproximately 30%. https://www.jegs.com/webapp/wcs/store...44819_-1_10265 |
Liberator for all of you semi owners.;)
2 Attachment(s)
ZugyNA -
Attachment 1026 Couldn't I just cut my stock exhaust tip to match the first or second example? Here's a longggggggg thread debating the snake-oil factor of the blade. It includes posts from a blade representative (look for posts from a guy named sabertec) : Blade Your Ride https://www.links4jeeps.com/phpBB2/vi...&postorder=asc I'm gonna do more homework on this. I would be happy if it had +- 0 effect on MPG but helped emissions. CarloSW2 |
JCWhitney sells or sold a muffler tip that uses a spring loaded butterfly to restrict the exhaust during cruise and increase mpg.
The spiral mufflers reduce back pressure and might increase exhaust flow by spiraling the gases. The Jegs spiral muffler looks like the best deal...not so sure it is sized right for a 4 cylinder though. When you see a bunch of idiots piling in on a subject and doing the ridicule thing...run don't walk. Just because it's the internet doesn't mean only bright people are on it. You test things by buying or making them, installing them, and then checking your resulting mileage. |
ZugyNA -
CarloSW2 |
https://www.gassavers.org/garage_imag...ry1wxmulun.jpg As others have stated, it only helps if I am into the throttle way beyond FE driving. But it is fun once in a while. I am a reformed psycho-driver. I had 8 speeding tickets in a 3 year period. I had to stop. I was driving way too fast for my age. I am kind of a ricer. I will put the same thing on my next japan made car also. I like the way it sounds, and I like the feedback I get from the sound. Not all gray haired drivers drive slow. |
That being said... I can't argue with a lab's statement... But the EPA documents outlining the 511 protocol seem to be a bit unclear... Is the 511 their own evaluation program that they do (as the introduction states), or is it something else? Quote:
In any case... the idea of adding back pressure does make sense to a degree (too much and you'll have ridability issues). |
trebuchet03 -
At $150, it's 3 times the cost of my sucker-limit, so I'm just gonna keep trolling around for information on it. It claims to reduce emissions (mostly during the cold start-up phase?). It makes me think it has a "filter" that you need to clean, but maybe it's just back-pressuring the exhaust into the cat in order to "cook" the exhaust a little more?!?!?!? Here's their diesel emissions gizmo that they used as the origin of the blade : https://sabertec.org/index.html Quote:
CarloSW2 |
