I've been deploring the lack of FE trucks at Gassavers for as long as I've been posting. I don't care whether it's old tech, new tech, or unobtanium. GM could build a FE Sierra from its own parts bin, equipped with a 2.73 to 3.23 axle, 15" wheels instead of those ridiculous 17's, electric power steering, water pump and fan, manual tranny and a 3.9 liter V6. It would get 25 EPA mpg without breathing hard. With gas over $3, ya gotta wonder why they don't. |
yeah, that ford had plenty of power with the 300, that was a really nice motor.
if you could get an FE tuned version of the 4.2 inline6 in the chevy with a 5 (or better yet 6) speed trans and a fairly tall readend (the 3.08 8.5 inch 10-bolt comes to mind) with a t56 in 2nd od (6th gear) and 235/70-15s about 65 mph would only be 1200 rpm and i think you could build enough torque with a FE/lowend cammed 4.2 to pull that out of the freeway, you would just have to not use 6th on slower roads, but you would have a second overdrive that was less tall to use the rest of the time Jeff |
I haven't read anything about it (to know if they're even trying or close), but I too saw the merits of the electric valves years ago and have been waiting eagerly. I've even thought about attempting it myself a few times but really don't have the time or money. Other added benefits, you no longer need to pump oil into the head, there will be nothing to lube up there. I think I read the main place oil gets heat sheered is the head because of temperatures there and the lack of fluid (much less resevoir up there compared to the oil pan), so this should instantly increase the milage you can get from regular oil between changes. Also we can finally get an efficient cylinder shutdown. Displacement on demand isn't much different than just killing the injectors to half the cylinders, during compression you're still stressing and losing energy you won't regain with ignition. With electric valves you can just make the intake open during every downstroke (assuming sequential injection so you would only be drawing fresh air) and open the exhaust valve on every upstroke, while the injector or cylinder is 'off'. This would drastically decrease how much energy an engine draws when not igniting. |
I work on the LS4 engine in the W cars. We have never had a problem with the lifters clogging due to oil breakdown. The oil pump is a higher displacement pump then normal to compensate for the new style lifters. When tested for durability the ecm is used to calculate needed oil changes. I know on our Buick that means 6500 miles. With todays oils even cheap ones this should not be a big problem. One of our engineers drove a Buick Lacrosse Super from Michigan to D.C. and he is no light footed driver and recorded 27.8 MPG not bad for 300 hp and as heavy as it is! I think most of us could see over 30MPG. I hope since my pay check is directly affected by GM's programs and with their 100,000 mile warranty in place, having them clog or shorten the life span of the engine won't be true. Remember that Chrysler also has a similar system, so does Ford I think?
Forgot to add that all of these systems default to max. number of cylinders they have. |
Spence |
The survey question was probably written like : If you could have paid $3,000 more and gotten a diesel with the exact same performance and 3 mpg more, would you have? And so people said no. |
Rick |
Every single time I read the title of this thread:
"Is GM getting smart?" I think "Doubtful." Every time... |
