GasSavers_Ryland |
07-08-2007 06:37 PM |
Originally Posted by Danial
(Post 62480)
A shop that knows Hondas inside and out.
That doesn't alwas meen it was done right, on most Honda's you line the marks on the cam sprocket up with the top of the head, but if you read the shop manual you'll notice that the VX is the exception, and that there are little arrow marks on the head that you line the sprocket up with insted, and over confident mecanic might not notice this set of marks and line the cam sprocket up with the top of the head insted, and this is wrong, of course you can check this your self by taking the cover off the cam gear, and lining up the crank shaft pully with the Top Dead Center mark, if everything is correct then the TDC mark will line up at the same time that cam gear marks line up with the arrow mark on the head.
the other option is to take it to the honda dealer, and ask them to take it for a test drive to figure out what is wrong, after all you said that you could tell when the vtec was kicking in, and this shouldn't be the case, other then a very very slight increase in power.
