Remember he added 14 inch rims.
The Swift GT (Metro) cars that came stock with 14's had additional body cladding & side skirts. |
Looking forward to seeing this one for sure, since I planned something similar.
As far as the tire clearance, it is fine now, but what about when you hit a bump ? I was going to make the lip on mine out of flexible rubber. Looking good ( or...will look good when you're done that is ) |
Really interesting! I've been contemplting something like that for my xB. I guess two observations. I agree the fairing should drop down to the air dam in front. I've been thinking of enhancing the flow out of the wheel well behind the wheel. Is there some advantage to more clearance after the wheel? Almost all the high-speed fendered cars have vents after the wheel opening or there's just no back to the wheel opening. Think of the Audi R10. Maybe just the front portion of the fairing would do the trick.
if you go to grassroots motor sports and to a search on how to make fender flares you will find out how. there is a guy who did a set on his yugo and they look good. from what i saw they are not that hard. give it a try and see. that wood stuff looks a bit shoddy.
https://www.jekylhyderacing.com/hyde/flares.htm did a search for you. you can make them as smooth as you want. |
2 Attachment(s)
The Insight's gently curved sides and wheelwells are also designed to minimize air turbulence. The plastic-resin front fenders extend downward below the centerline of the wheel and incorporate a small air dam in front of the wheel. To further minimize turbulence, the trailing edge of the wheelwell is inset and faired into the body. Disc-shaped aluminum wheels also help smooth airflow around the wheelwells.
This is a quote I found? Why isn't it better to just slide over the whole wheel. The idea is to mimic old reliable but simplify that design. Which to my mind is very inventive. |
Front end experiment.
2 Attachment(s)
Worked on the fenders tonight. Took off the right side, good thing that it was removed need to do some sandblasting to the unibody. Thankfully its not to bad. Old fender is another story most of it is on the garage floor in the form of rust dust. The fender flare extension is on the new fender. After that took some time to close up the radiator opening. Used easily removed components incase problems arise.
Repair to rocker panel
6 Attachment(s)
Got started repairing the rocker panels. Took longer than expected doesn't it always! Found more peanuts hidden away by the mice 7 years ago. Car doesn't flex as bad now. Will begin boxing in the rockers in the AM.
Whew!!! Guess I kinda forgot how bad rust can be. We've been in Colorado many years now but lived in Illinois before. As bad as Michigan. I now remember that thinking about and planning rust repair was probably (no,surely) THE major concern on older cars. Well, you're digging in, getting started is a large part of getting it done.
Good luck, waiting to see it finished. CO ZX2 |
Why can't we buy cars with optional stainless steel frame, axles, etc.? I'm taking such good care of my drive train it's sure to last far longer than the frame here in Wisconsin. Answer: Most people WANT to change cars about every 5 years.
