Today I duplicated his - the hatch was wide open. I don't believe anyone's done a test with the hatch only unlatched & cracked open a little bit. |
The thing I always look for is a very consistent spot that I can go to one day to the next that always gives me the same speed/distance. So anything that would be more involved than removing a few screws to change I can do over a few days. The only thing I have seen that changes my distances on tests from one day to the next is really big temperature changes so if the temp changes by more than maybe 20 degrees F a day then the numbers wont be quite as good. The best way I have found is to pick a spot or a few spots and keep doing the test anytime you happen to be around there. This helps let you know if that spot has good repeatability for doing tests over the course of several days. Once you have a spot you know exactly how your car does consistently on, testing like this becomes way easier. |
I don't think I'll be able to easily find terminal velocity on this hill - it's not long enough (and there isn't much of a "runway" before the top to build up speed either).
I wonder how repeatable your data is. Like if you ran three trials with the same settings, how close would your distances be? Hmm.
That's the key, isn't it?
Next time I try it, I'll be collecting data from multiple runs to answer that question. |
Answer to that question:
Well, you could do a "control" run every couple of test runs, and then correct for any apparent improvement across runs. Know what I mean? Not ideal, but pretty defensible.
Well, you know what? This "problem" could be an opportunity to do a test.
I played a little with terminal velocity tests on hills and am thinking that I might get a more accurate test to test result by taking the acceleration factor completely out of it... by seeing what terminal velocity is "reduced" to rather than "increased" to. ie. hit the top of the hill faster than your expected terminal velocity and let aero (and RR) forces decelerate you to terminal velocity...
On paper it shouldn't make a difference but in practice you can hit close to terminal velocity at the top of the hill and get the reading for a much longer duration (than hitting the top at say 50 mph and seeing how high you speed gets by the bottom). I have not tried it yet though... just seems to make the experiment a little more controllable and eliminates all factors other than aero and RR. |
Removing variables is always good.
I need to make a chassis dynamometer to pre-warm my drivetrain. :D |
