With the 4T65E-HD (4-sp automatic) I can control shift point, TC lock-up, and other parameters with my tuner.
I am sure there are ways to adjust settings on most electronically controller automatics. For the older automatics (example: 92-95 Civics) has anyone tried changing gears to lower the highway cruising RPMs? |
diamondlarry -
CarloSW2 |
Speaking of Manual
I located the shop manual and noted that I can override the TC engagement through manually engaging 1 or both of the 2 TC lockup sensors via 5V power. Judging by the schematics, it may bypass the VSS and TPS to make the final decision to lock up through the switch override -- I'd just have to be mindful of speeds and coolant temps to prevent further damage to the trans. Of the 3 settings of full, partial, or zero lockup, one sensor allows partial, and the other engages full and uses the Hill/Fuzzy-Logic adaptive computer for shifting (argh). So, during the colder months, perhaps 2 toggles could manually engage these at lower TPS settings once the speed allows. Purely theory.
I'll tell ya, that 50-page section on the automatic transmission looks more complicated than open-heart surgery. Sheesh. :confused: If you're stuck with an auto, I reccommend finding a shop manual that describes exactly what parameters the transmission requires. Further inspection could perhaps find a way to take control of that vicious dictator: the Transmission Control Module. RH77 RH77 |
Wow thanks for all the responces! I could swap in a Camero 6 speed transmission. I've had two 5 speed manual cars before. On both, I notice if I short shift, I can get better than the EPA highway milage, in the city. I have a 700r4 transmission in my caprice, I would have trade in the newer electrically controlled one and program differnt shift points.
caprice -
1996 CHEVROLET CAMARO https://www.media.gm.com/ca/gm/en/pro...996Camaro.html Quote:
and with my gear ratio and tire size, at 75 MPH the engine would be turning 1500 RPM :D 50 MPH is 1000 RPM. With the low end torque of a 5.7 liter engine, I'd have no problem :D If I want a little passing power, I could just down shift.
https://www.f-body.org/gears/ |
It would be cool driving a huge car with a manual short throw shifter. Like the one in Underworld.
synthetic tranny fluid?
How about synthetic transmission fluid?
I've seen some posts elsewhere saying that's definitely the way to go. Any benefits to FE, or just that it lasts longer and probably protects the tranny better? |
From a FE perspective, the main benefit of synthetics is their cold performance (viscosity). They don't thicken as much as mineral fluids as temps drop.
People who live in a year-round warm climate would probably see no FE benefit from synthetic use. Note that no major synthetic brand claims fuel economy improvements with their use. |
