-   -   Do you trust your speedometer/trip odometer? (https://www.fuelly.com/forums/f8/do-you-trust-your-speedometer-trip-odometer-3536.html)
GasSavers_DaX 01-09-2007 11:57 AM
Originally Posted by omgwtfbyobbq
I demand you adjust your mileage logs and drop below 40mpg instantly! ;)
I am adjusting my logs now. My findings show the odometer UNDER reporting by 1.85%...therefore I'm ADDING 1.85% to what the odometer shows, thus raising me higher above 40mpg instantly! :p
omgwtfbyobbq 01-09-2007 12:04 PM
Noooooooo! :thumbdown: :eek:
:D ;)
Gary Palmer 01-09-2007 01:12 PM
According to mapquest, mine is off by a third of a percent. But then again, mapquest may be off, so who knows?
You are truly Hard Core!!!;)
omgwtfbyobbq 01-09-2007 01:30 PM
I suppose have to be to drive 55 in CA... :D
rh77 01-09-2007 10:02 PM
Rental Experience
After renting many different vehicles, I'd venture a guess that the Speedo/Odo is off 80% of the time. The most radical is in the Kia Spectra: Actual speed = 60, displayed speed = 65. Toyotas are also a off the mark in this direction, pretty consistently -- especially the Camry. The domestic brands tend to be close to the mark -- Ford and GM tend to be pretty accurate. I haven't come across a vehicle that is faster than it's indicating.
My theory is that the tolerance given to manufacturers to allow a higher reading: makes people think they're going faster, and they slow down. In the meantime, the miles stack-up and the warranty expires sooner :confused:
RH77
jwxr7 01-10-2007 05:43 AM
google earth
my odo and google earth were within 1/10th of a mile for my 23 mile commute route. That's gotta be within the probable error of things.
JanGeo 01-10-2007 07:00 AM
My xB is reading 10% low on the odometer but I have been adjusting for it all along - it sort of extends the warrenty by 10% which I will not complain about. The Speedometer reads higher than actual of course but the needle doesn't even reach the marks on the dial so I don't look at it much except when reaching redline on the tach. It is nice to see the TomTom, Garmain, ScangaugeII and roadside radar all agree on the speed however.
