-   -   Does a bearing poop in the woods? (https://www.fuelly.com/forums/f11/does-a-bearing-poop-in-the-woods-12957.html)
kamesama980 10-12-2010 05:36 AM
Re: Does a bearing poop in the woods?
Originally Posted by ************* (Post 155137)
It turns out, the bearings are usually double ball bearing which totally sucks imo.. I'm going to try to find a way to see if I can get some tapered roller bearings for my civic in place of these ball bearings.. Totally disgraceful that they'd use ball bearings.
good luck with that. for the price of finding bearings and machining the hub/spindle to accept them you could replace the balls a couple times probably.
I just checked on parts listings on rockauto, the front bearing up till 2002 is a NON SEALED double row ball bearing that's pressed in. you can mess it up installing it but more likely, they haven't replaced the grease seal (many places do overlook this) and it isn't sealing anymore or the polished area it mates to is damaged causing even a new seal to not do it's job.
after 2002 it's a self sealed version of the same thing.
Could also be something like a bent hub (or wheel if you haven't rotated the tires) or damaged knuckle causing problems.
norurb 01-14-2011 04:46 AM
I apologize if this is considered bringing back an "old" thread.
My '92 Infiniti G20 went thru a couple of front left wheel bearings in 2 months. Then I realized the hub needed to be changed ALONG with the new bearing. Our 3rd attempt was a success after changing both the hub and wheel bearing. I spent $40 for the ebay hub and $20 for the ebay wheel bearing.
