Wow! Great project. My car has several similarities to yours:
I have 7.9:1 compression, pentroof combustion chamber, dished pistons, turbo, programmable ecu with lean burn. I've thought about rebuilding my engine with higher compression, but it's still running so I keep using it as is. I just wish my results were as good as yours. Have you thought about using beehive valvesprings? They've just become popular in my corner of the tuner world. It seems they allow lower seat pressure, which reduces valvetrain friction, while still keeping the valves from floating or bouncing at high rpm due to the harmonic damping abilities of the variable diameter. |
Oh yeah,
Oil squirters keep pistons cooler so you can run tighter piston clearance. Does your engine alredy have them? Is there any way you could swap in a taller 5th gear from another drivetrain? Have you considered using a custom cam with late intake closing to produce a Miller/Atkinson cycle effect? |
I had beehive springs on my Turbo 93 Talon AWD. They do work great!!! Compared to my Talon the Honda spring seat pressure is lower then the Talon's so I stayed with the ZEX springs. |
I do need a taller 5th gear so i'm going to be swapping in a VX 5th gear. I'm looking at having a custom cam ground to take advantage of the Miller/Atkinson effect. When I do this I will probably have to increase the compression though? |
When the car is in lean burn mode the AF ratio varies with load. At medium loads it's around 17.3 to 17.8. |
They share the same 1st gear 3.25 2nd gear 1.90 3rd gear 1.25 4th gear.909 final gear 4.250 ratios the only difference is the 5th gear .702/.750. I know its not to much of change but my plans are for only a 5 mph increase at the same rpm using the .702 with a taller tire.(so I can cruise at 65mph freeway speed) I tried a VX tranny with my engine combination and it actually was a lot worse then with the Si trans. Now if I had better aero mods I could use the VX transmission at a higher mph and it would probably work very well. |
Thanks for the info!!!:thumbup: |
