-   Electric and Solar powered (https://www.fuelly.com/forums/f18/)
-   -   Electric conversion: Project ForkenSwiift (https://www.fuelly.com/forums/f18/electric-conversion-project-forkenswiift-1605.html)
CO ZX2 05-03-2007 05:34 PM
Originally Posted by MetroMPG (Post 50050)
Hi, CO - is it as technical as it sounds? Would it cause me to stray from the path of "winging-it-ness"? :)
:thumbup: :thumbup: :thumbup:
This is a 5 page pdf only 65 KB. I could understand some of what they were talking about and I know very little on this subject. With what you have been thru in the last year, you should have a pretty good understanding of it. Interesting comparisons and graphs even if you don't use it.
Tell me how to get it to you and I will get it done.
MetroMPG 05-03-2007 05:36 PM
Sure thing: fire it off to darin [at] forkenswift.com. Thanks!
MetroMPG 05-04-2007 06:26 AM
Just noticed 2 separate visits from "Shanghai Kowin Automotive Components Co. Ltd" in the forkenswift.com traffic log.
First ever visitor I can recall seeing from China on any of my sites (that I monitor).
I sure hope we're not giving anyone any ideas for production vehicles! :)
rh77 05-04-2007 07:03 AM
Even with the censorship -- not bad! But yeah beware, they tend to take ideas and manufacture their own version (limited International patent enforcement). But -- if it helps keep them from buying a bunch of Cadillacs to reduce their Carbon footprint, then I guess "by all means".
Bill in Houston 05-04-2007 07:26 AM
Ya, they'll start buying up rusty old Swifts and drive up the prices for the rest of us. :-)
MetroMPG 05-04-2007 08:55 AM
Or worse: cornering the market on used 6v batteries!
Bill in Houston 05-04-2007 09:46 AM
Nah, they could never afford the freight. ;-)
MetroMPG 05-06-2007 05:49 PM
So I forget whether I mentioned: we're going to take the car up to the
MetroMPG 05-10-2007 01:09 PM
I've been chipping away (literally) at the body
trebuchet03 05-10-2007 05:51 PM
Originally Posted by MetroMPG (Post 50903)
Sadly, paint supplies ($45) finally pushed the total built cost past the $1000 CDN mark. :(
Meh, it's safe to say body paint isn't part of an EV conversion :p EV or not, you'd be doing the same thing :D
Bill in Houston 05-11-2007 04:42 AM
Time to recycle more batteries!!
MetroMPG 05-11-2007 06:17 AM
There will be some more batteries to recycle soon. I still haven't tried the "new to us" Ranger EV batteries in the car yet, but there's no doubt a number of the old forklift co. floodies will be recycled.
MetroMPG 05-11-2007 06:27 AM
Here's a thought for anyone else considering a conversion. If you're going to try hypermiling your EV, you might want to=
MetroMPG 05-11-2007 06:32 AM
True enough. If I exclude all costs that aren't strictly EV parts related, we're WELL under $1k!
Bill in Houston 05-11-2007 09:45 AM
So you don't normally shift when you drive it? You just pick a gear and stay in it?
MetroMPG 05-11-2007 09:59 AM
I shift, but upshifting seems much easier than
MetroMPG 05-11-2007 10:09 AM
Should add: some "proper" conversions don't need to be
Bill in Houston 05-11-2007 10:22 AM
Okay, I see. I'm sure that it would be easier with a tach. Have you thought about putting one in?
MetroMPG 05-11-2007 10:37 AM
Thought about it, yes. It would be useful in more ways than one. Question is: how to do it on the cheap? :D
Good news on the build cost front!
MetroMPG 05-11-2007 10:44 AM
For anyone counting (I am!), that brings the net cost of the parts we kept from the old Baker (2 pump motors, cabling, EV-1 controller, fuses, contactors etc) to $34.95 after recycling refund & the drive motor sale.
Bill in Houston 05-11-2007 11:35 AM
Don't ask me! You're the smart one! :-)
I think that some really smart guy would say something about sticking a rare earth magnet somewhere as a pickup, and then some sort of chip, and some sort of counter circuit, and some sort of display. It was really easy for the Electrical Engineering geniuses on the Prius groups, but it made no sense to me.
Personally, I'd be searching junkyards for an old timey mechanical tach, and then figuring out where to hook it to the motor...
Oh, and great news on the torque monster...
SVOboy 05-11-2007 11:38 AM
Yay for 700th post, looks like everything is going okay for you, darin.
This thing is ending up so cheap, perhaps you can upgrade it's range/top speed a bit?
MetroMPG 05-18-2007 03:27 PM
One thing I was thinking: just attach a tiny dc motor (or a magnet and coil pickup) to the drive motor's end shaft and calibrate its voltage to the motor RPM (which we can back-calculate based on vehicle speed, knowing the transmission ratios). Then make up an analog volt gauge that ties it all together....
Silveredwings 05-18-2007 04:46 PM
If the car came with a tach, then it probably is an analog votmeter. The way they worked with mechanical points is that the low voltage coil wire would send pulses to the tach. Inside the tach is a capacitor with a bleed resistor. The pulses would charge the cap and the resistor would discharge the cap. The faster the pulses charge the cap, the higher the voltage and resulting needle indication. As the pulses slow down, the continuouse discharge through the resistor allows the voltage (and needle) to fall. It's so simple that something similar must exist on electronic systems using a hall-effect device that gives the ECU it's engine position information. The ECU probably sends a cleaned-up pulse from the hall-effect device to the tach (that's my guess).
Since there's no ECU, you may be able to simulate the pulses by using an optoisolater which is a colocated LED and photo-transistor with a small separating gap between them. Mount the optoisolator close to a rotating part of the motor (like the coupler) and some kind of shutter glued to that part so that as the 'fin' revolves, it interrupts the gap. To avoid balancing issues with the rotating mass, the shutter should be made out of something opaque but lightweight like a small piece of aluminum flashing. The tach is calibarated to a specific number of pulses per revolution according to the number of cylinders the ICE had. You would want that same number of interruptions (pulses) per revolution. Does any of this make any sense??
MetroMPG 05-18-2007 05:07 PM
Yeah, that makes sense. Unfortunately neither the red or blue cars had tachs. I'm pretty sure some computer mice used optocouplers connected to the ball to detect movement - was thinking if I were just a bit smarter/more motivated, I could hack one of those to do something useful :)
Say... how's the Healey?
Silveredwings 05-18-2007 07:01 PM
The Healey patiently waits. My oil pressurization attempt didn't work (20W50 with stabilizors was too thick) and I seem to need to rebuild the starter...but the lakehouse has a new roof and life goes on... ;)
So... is a junkyard tach an option? If so, I'm fairly certain you could make one work. The advantage (besides asthetics of an oem part) is the nice big 270 degree sweep of a tach movement. Also, if the inertia of the movement is high enough, you can skip the capacitor and resistor I mentioned above. See this most helpful article: https://www.4crawler.com/Diesel/Cheap...x.shtml#Theory
MetroMPG 05-21-2007 05:02 PM
Cool - thanks for the link. Glad to hear about the new roof too :)
pauldl63 05-22-2007 10:12 PM
hello,this is my first post on this forum and i would like to hello to everybody.after reading what's been done to build the forkenswift I too are considering the same sort of project,while looking through the US ebay sight I came across the listing which I thought might be of some interest to somebody.
https://cgi.ebay.com/ebaymotors/ws/eB...2757298&rd=1,1
anyway all the best,cheers---palu
MetroMPG 05-23-2007 03:21 AM
Hi Paul - welcome to the site.
That motor would be fine for a large vehicle - it's a beast @ 375 lbs! (I thought the Torque Monster was heavy @ 240.) The main challenge would be finding / making a controller for it, since the field is separately excited, rather than the more common series setup (some people run 2 controllers - one for the armature, one for the field. You can also buy dedicated Sep Ex controllers).
The shipping cost will be the other big challenge.
Funny: I've had 3 inquiries about the Torque Monster since receiving the deposit for it. Which makes me think that, as usual when I sell stuff, the price was probably a bit too low :o
Silveredwings 05-23-2007 11:34 AM
So I had to replace the Healey starter. It was a crude little series-wound motor that could be rebuilt, which I attempted, but the commutator was WAY out-of-round so I surrendered after almost a day of effort. Maybe I'll log it as training for some future EV work. :)
As for the rest of it, it'll have new: carbs(x3), fuel & water pumps, belt, door latches & strike plates, trunk lock (its the only thing that does lock), hoses, thermostat, cap, rotor, condensor, plugs, points(x2), and fuel filter. Rebuilt starter, speedo, temp/oil combo guage, gas tank, and a whole lot of et cetera.
BTW, congrats on your 4,000th post. ;)
MetroMPG 05-23-2007 05:20 PM
I don't know that 4000 posts is a thing to be celebrated! :confused:
So, do you have to come up with another means of pressurizing the oil now? Could you pressurize it with something lighter just to get it lubed & turning over, and then drain & refill for the big fire-up?
SVOboy 05-23-2007 05:23 PM
Pictures! I demand pictures...
MetroMPG 05-23-2007 05:28 PM
I'll take some on Sat at the EVent. :)
Silveredwings 05-23-2007 05:55 PM
That's probably what I'll do but I need a container that I can easily pressurize (only about 20 psi). I tried a big liquid laundry detergent container but the plastic stretches and looks like it's going to pop. :(
Those stripes and paint detailing sounds great. I can't wait to see it. :thumbup:
Bill in Houston 05-23-2007 06:31 PM
A 2-liter bottle can take a lot of pressure. If it worries you, put it into a 5-gallon bucket of water to contain any "blast force". Like they do when they are filling SCUBA tanks, if you have ever seen that.
Something I heave read about on small block chevy engines is to remove the distributor, attach a drill to the distributor/oil pump shaft, and spin it with a drill.
SVOboy 05-26-2007 06:34 PM
Will we be seeing more pictures, Mister CBR125 Exporter Sir
Silveredwings 05-27-2007 03:54 AM
Is that an old picture? It looks like autumn.
MetroMPG 05-27-2007 04:21 AM
Mr. CBR 125 exporter says:
- Ivan took his camera.
CO ZX2 05-27-2007 05:39 AM
Great pictures.
Forkenswift sure is shiny now. Wheels, tires, underside of hood is amazing; must have spent hours scrubbing and polishing there alone. Kept looking for the stripes, must be along the bottom sides??
Looks like you had a warm, sunshiney day and a lot of people.
Should of had a Low $$$ prize. I'll bet no one would else was close.
Congratulations on getting it spiffed and running for the show. Proud of you.
MetroMPG 05-27-2007 06:02 AM
Ah - now I see what you were getting at.
It's recent as in sometime in the past couple of years.
