Good link, clencher. You're the link man for sure.
The thing I keep coming back to is only the 15% loss on the alternator. I find it really hard to believe that an alternator can turn 85% of the mechanical power in to electrical energy. Maybe they do, but it seems really high to me. Heck a switching inverter is lucky to be 90% efficient with no moving parts. And a DC motor attached to an AC motor is also only about 50% efficient. So how the heck can an alternator be more efficient then a motor inverter? I would think an alternator is about 50% efficient at the top end. Maybe I am all wet, but this just doesn’t sit right with me.
It also wouldn't explain the larger gains we are seeing by disabling them. 100w or less then 1/4 HP should mean a 10% increase in mileage HP wise. Maybe they are 85% efficient at 50% loading and only 25% efficient at 10% or normal loading? |
Numbers I get from eCycle is that the alternator is about 60% efficient but again at what load. They have a pretty free spinning rotor even when magnitized and slip ring brushes so not much loss there so you get into I2R losses at high currents and the diode drops all the time. It really comes down to how much current the car draws constantly . . . 20 amps at 14 volts is 280 watts doubled for 50% efficiency is still only 560 watts . . . add some belt and fan losses in the alternator and you get less than 1 HP. If you like I can run an alternator on an electric motor and tell you how many watts it takes - all I need is a belt and pulley for the motor.
Sounds like way to much work but I would be curious to know what it really takes to drive the alt.
It's funny you mention that because one of my first thoughts was to drive the alternator in my car off a 1 hp DC motor from the spare battery. Seemed like an evil circle and I thought the losses would be less to go the inverter/charger route. It also allows me to very easily re-connect the alternator for trips or if my wife takes the car. |
Posting this message on behalf of John David Shelton, who is the founder/moderator of the MaxMPG Yahoo group: https://autos.groups.yahoo.com/group/maxmpg/
John David is currently serving in Iraq. He has limited bandwidth (thus the request to post this for him). EDIT: his personal web site: https://maxmpg.org/ Feel free to reply to his thoughts on alternators / charging (prompted by this thread and my write-up at metrompg.com). He periodically reads stuff here at GS. Quote:
I'll take a stab at a couple of John David's points...
You know I was just thinking if we knew the amount of watt hours that we would need to operate for a desired time how about using a higher voltage NiMh or NiCad pack and regulate it to 14 volts out - I have some cheep 20-60 volts input 15 volts out (adjustable) - switching regulator modules 80% efficient and since the NiMh battery can be cycled a lot more than an SLA that could supliment the cars 12 volt battery and you could run a 12 volt to high voltage charger to recharge when going down long hills or slowing down although that recharge time would be minimum - solar or grid recharge would be easy enough at higher voltage.
Would a larger battery require more amps to recharge it if the ammount of discharge to start it is the same? |
Diesels vs. Gassers
Unfortunately, gassers need ignition/spark to operate, whereas a Diesel doesn't need a battery once running. This and the electrical systems such as power steering on newer cars would require quite the load.
If you know your maximum commuting distance, adjust it for temperature, and perform the calcs, I'm sure a zero-alternator/plug-in system could be implemented. The cost/weight is up to the experts... RH77 |
