xylene?? - Fuelly Forums
Old 04-27-2006, 01:59 PM   #1
xylene??
Anybody out there experiment with xylene for mileage. I just saw an updated article that says it is a big mileage gainer.
http://www.lubedev.com/smartgas/ultra5.htm
benhuey is offline   Reply With Quote
Old 04-27-2006, 03:52 PM   #2
Re: xylene??
I have, actually. Xylene is basically what is added to gasoline to increase its Octane Rating. I used to buy it by the 5-gallon can and mix my own 100-Octane fuel for my Turbo EVO. Since the vehicle required a higher octane to function at it's peak, I noticed 2-3 more MPG with the addition of it and LOT more power and boost. For the average, normally aspirated, regular-compression engine that requires 87-Octane, I don't see any reason in using it. I'll read the article to see what it sez...
Old 04-27-2006, 08:56 PM   #3
If you had an engine with a
If you had an engine with a knock sensor and it was retarding spark due to knock, this would help raise the octane of the fuel, stopping the knock, and allowing it to advance and run more efficiently.
If your engine can run fully advanced on 87 octane, I bet it buys 0 mpg.
Yeah, I've got a race car too, and I used to mix this or toulene with 93 octane to raise the octane a bit. I've since detuned it a bit to run on 93 again.
cheapybob is offline   Reply With Quote
Problems with Badges DTMAce Fuelly Web Support and Community News 4 04-25-2012 02:37 PM
Need help. Nettle General Fuel Topics 13 12-06-2008 11:18 PM
Find friends disappears after adding a friend tggbenz06 Fuelly Web Support and Community News 2 08-30-2008 05:14 AM
Just fired up the swamp cooler Matt Timion General Discussion (Off-Topic) 13 08-04-2006 06:43 AM
im going to the track on thursday. anybody want to place some bets? thisisntjared General Discussion (Off-Topic) 14 04-14-2006 10:21 AM
