Window screen vaporizer - Page 2 - Fuelly Forums
Old 05-10-2008, 07:02 PM   #11
kamesama980's Avatar
Originally Posted by flapdoodle View Post
This was an interesting and inexpensive experiment, but has not worked for me. Using the same "test path" I got 9.04 MPG without the air conditioner on. Previous test was 12.96 MPG with the air conditioner on. The pantyhose filters will be removed.
I think it's a little too tight of a mesh, not enough open space. you're trying to break up the gas droplets, not filter everything out.
-Russell
Old 05-12-2008, 09:01 AM   #12
Yup, considering aviation pioneers used oiled silk for lifting surfaces, you're only a PCV splurge away from effectively sealing off your intake altogether
Old 06-05-2008, 01:20 PM   #13
I had an extra spacer that goes between the TB and the intake so I have glued a screen to both the top and bottom of it and will eventually get around to testing it. Right now I am testing the results of adding a tube of Xado and 1 oz FP-Plus per 10 gallons. Looking at my gas gauge it looks like I am getting good results from these two mods. It will be reported in the garage as soon as I get results. Sure wish my ScanGauge worked on OBD1 since that is my test car.
Hipermiler
#47 on my way to #1
Old 06-05-2008, 01:29 PM   #14
High rise manifolds are expensive, but increase the performance or cut fuel needed for same performance.
Spacers between the carburetor or throttle body injectors and the manifold will do the same distance increase as the high rise manifold.
Forget the screen, just add the spacers.
Not of any use with port injection or direct injection.
Old 06-06-2008, 02:19 PM   #15
tried a stainless screen... no noticeable change. used a rubber/fiber gasket on either side sandwhiching the screen. might try adding another layer at 90* just because it was mentioned to do better test procedures but since it didn't hurt any, I'm not gonna bother taking it out. oyea and lots of RTV in the middle of the sandwhich too.
if you're ever looking for stainless screens, take a trip to any department or home products store and look for sink/bathtub strainers. they're stainless, already domed usually, and about $.75 ea. tops
-Russell
Old 06-06-2008, 03:06 PM   #16
Aren't there faucet aerators that are also domed and stainless? Might be cheap too. less than $75, that's for sure. I think you meant to say $.75, right?
JV-Tuga is offline   Reply With Quote
Old 06-06-2008, 03:09 PM   #17
yep,,,I agree
COMP is offline   Reply With Quote
Old 06-07-2008, 05:20 PM   #18
I did mean... corrected. the problem is that most faucets are 3/4" wide at most. that wouldn't even fit one of the carbs on my bike with enough left to hold it. my trucks throttle body is 1.5-2" wide. the drain screen fit perfectly
-Russell
2007 Lifan LF200GY-5 Review CoyoteX Motorcycles 16 11-21-2012 08:07 AM
WTB OBD0 civic distributor budomove Wanted to Buy 5 11-26-2007 02:50 PM
passed by a prius Erdrick General Discussion (Off-Topic) 10 11-25-2007 06:02 AM
Metro's thread about relaying a package got me thinking... omgwtfbyobbq General Discussion (Off-Topic) 3 07-31-2007 03:03 PM
