Wideband controller for monitoring - Fuelly Forums
Old 09-21-2014, 07:35 AM   #1
Wideband controller for monitoring D15Z1 lean burn
I have a D15Z1 and am using the L1H1 sensor and P07 ECU.
Since there are a bunch of wideband controllers out there that use the L1H1 sensor, I'd like to hook one up so I can use the gauge for monitoring AFR.
I just want to make sure tapping into the needed wires for the wideband controller wont screw with the readings that the ECU receives.
Also, are there any wideband controllers & gauges that can read leaner than 20:1?
imagine-02 is offline   Reply With Quote
Old 03-09-2015, 08:54 AM   #2
On the newer Hyundais and some old ones they come with a WBO2 as stock. You can get the Torque App and the Hyundai Advanced plug on to monitor what the actual calues is.
Don't know what car you have,
RedRaspberry is offline   Reply With Quote
