--- What temp to heat Gas to? --- - Page 3 - Fuelly Forums
Old 08-12-2008, 09:01 AM   #21
trautotuning's Avatar
I checked my thermostat and it appears to have a 195 degree thermostat btw.
Old 08-12-2008, 10:18 AM   #22
I'm using a fuel heater on my Geo Metro. An image can be seen here
www.livesteaming.com/metro.htm
I have to admit I was nervous about using but after running it disconnected from the fuel supply for a week I hooked it up.
The copper fuel line got too hot to touch without fuel. With fuel it is just warm.
I cannot tell you if this mod has made a difference because I do not have the time to test every mod individually. I'm happy though with the current approx. 62 mpg.
TH
Trevor Heath is offline   Reply With Quote
Old 08-12-2008, 10:53 AM   #23
flapdoodle's Avatar
I don't mean to criticize, but I am curious why we would want to heat the fuel when the manifold is heated, and with the warm air intake the fuel would quickly become whatever the intake air temp is.
Old 08-12-2008, 11:15 AM   #24
AMX
Originally Posted by philip1 View Post
Liquid to air intercoolers are capable of exceeding 100% efficiency, however I have not seen them used to heat another liquid. I am watching this thread. keep in mind gasoline boils at 110*f unpressurised pressurizing it to 55psi only raises the boiling point to 159.8*f I would be careful with this project. very careful.
Nothing can be more than 100% efficient. If something is more than 100% efficient, then you are creating energy from nothing, and have just solved all of the worlds problems!!
AMX is offline   Reply With Quote
Old 08-12-2008, 11:18 AM   #25
Fuel injection has a cooling effect as the fuel evaporates into the air causing a drop in temperature. If you can add the heat needed to make the fuel vaporize you wont have to take it from the air after injection. Toyota relies on this for their Tundra and 4Runner TRD supercharger kits.
Why heating the fuel gives a benefit? The point of a WAI is to make the air less dense so you are basically decreasing displacement by decreasing the amount of air the engine can take in. This means you have to give the engine more throttle to get a given amount of power and you get reduced pumping losses as a result. The heated fuel keeps the air from cooling down just before it enters the cylinder.
- Kyle
Old 08-12-2008, 01:22 PM   #26
liquid to air intercoolers can cool the charge air to a temperature lower than the ambient temperature exceeding 100% efficient. This requires very cold water on the coolant side. an air to air intercooler maxes out at 70% efficient due to the fact that it is using air to cool the charge instead of water. I am not trying to solve any problems just explain the difference between an air to air and a water to air charge (inter) cooler. the water to air is capable of exceeding 100% due to not relying on the air for all of it's cooling capacity.
Old 08-12-2008, 02:49 PM   #27
Just because it cools to less than ambient doesn't mean it's over 100% efficient. To be over 100% efficient the intercooler would have to cool the air going through it to a temperature lower than the coolant going into the cooler.
What you are talking about is just 70% efficiency with a lower starting point than ambient which is why it can cool to lower than ambient.
- Kyle
Old 08-12-2008, 03:20 PM   #28
AMX
It's like 'dkjones96' explained it. He is correct. NOTHING can be more than 100% efficient. It defies the laws of Physics. Also, I have never known of anything being 100% efficient. There are always losses.
Old 08-12-2008, 05:55 PM   #29
In my opinion this is nuts. All of you know that when you heat the gas you are running on mostly vapors which are much more volatile than liquid. I wouldn't feel safe in a car that the fuel was 400 degrees.
Am I wrong or right in this thinking?
exhaustartist@gmail.com is offline   Reply With Quote
Old 08-12-2008, 06:50 PM   #30
Cool
Oh no, you are so right But that is why I am trying to find an ideal temperature to heat it to, I do not want to go 1000000F if I am going to explode! Hahaha
Matching EPA Type to My Car DastardlyDan Fuelly Web Support and Community News 2 10-26-2009 07:16 AM
Hydrogen or H2O Systems 1Jal1 General Fuel Topics 4 10-11-2008 02:20 AM
Why did it take me so long to find this place? Baranfin Introduce Yourself - New member Welcome 6 05-31-2008 05:17 PM
Higher speed not as bad as I thought mrmad General Fuel Topics 16 09-22-2007 10:55 PM
