Vortex Generators / Hmmm Airtabs - Fuelly Forums
Old 12-30-2006, 08:51 PM   #27
GasSavers_Red's Avatar
Tested out my AirTabs(AT) today on a 400ish mile day trip (391.8 miles).
The Short and Sweet
#'s taken using a ScanGauge II
Baseline MPG average no AT: 19.1 MPG (@ 70 MPH)
MPG w/ AT: 20.5 MPG (@ 70 MPH)
Difference: +1.4MPG
% Change: +7.33%
Total Cost: $34.24
Recap:
AirTabs are designed for use on Tractor Trailers. A quick recap of what AirTabs are supposed to do:
  • Increase gas mileage
  • Cut down on vacuum region aft of a trailer by creating vortexes in the air stream
  • Prevent dirt and debris build up on the rear of the trailer
  • Reduce the effects of wind gusts
Conditions:
I mounted the AirTabss near the end of the hardtop. Approximately 6 inches from the rear edge. Due to the rain channels formed into the fiberglass of the top, I was unable to place the AirTabss as were recommended. Instead I mounted two AirTabss in between each rain channel and 1 AirTabs at each end channel. I'll post a picture up tomorrow to better illustrate this.
Temperatures were around 40F for the duration of the trip. The experimental duration of the trip was taken from a Safeway gas station in Fairfax to Truckee. I stopped at the same station on the way back. The 60ish miles to Fairfax from my place was used as a "Warm Up" to make sure all various parts are at optimal operating specs and temperatures.
Cruise control was used for the entire duration of the trip. Cruise was set to 70 mph as determined by the stock speedo, the SGII displayed actual speed as 68 mph.
Terrain was a mix of flat land, moderate to steep climbs and moderate to steep descents along with a few miles of city driven to get to the ski park and get lunch. Elevation ranged from 50 ft above sea level to 7000ft.
Comments
Initial driving impressions earlier in the week verified the additional stability in gusty situations. We had some nice 25-30 mph gusts around my house on Thursday. Usually the Jeep gets blown around that you are conscious of your steering input, however with the AirTabss I barely noticed the wind's effect, noise rose but the Jeep did not rock around. Prior to the AirTabss when I would pass a Semi I could feel that I was driving through a thick wall of something, I could literally feel out a trucks wake, again now I barely notice anything, I have to use the SGII to figure out whether or not I'm in a sweet spot.
After my trip up to Truckee, the rear glass and tire carrier was noticeably cleaner looking than what I usually end up with. I did not have to use my rear wiper once to clear out the crud. Also the usual piles of road dust was much smaller than usual. Rather than a literal pile of sand and salt, it was more of a medium coating along the edges and a very light coating closer to the top and middle. (Will add a pic later)
As for gas mileage my trip average with the AirTabss were 20.5 beating my usual average of 19.1, an increase of 1.4 MPG. The average was computed over 268.6 miles following the exact same route, so it should be a fairly valid #.
I did notice that when shutting cruise off, usually the Jeep would feel like you hit something and generally drop 3-5 MPH, with the AirTabss you don't get that jolt nor sudden deceleration anymore, the Jeep feels like its coasting for a bit, slowing down almost normally.
Conclusions and Comments
For 30 bucks worth of plastic, not bad for a 7.3% gain in FE. But if 7% equals around 1.5 MPG this kinda sucks. 7% seems like such a nice big number and 1.5ish is so small... Ahh well whatever, breaking 20 MPG on a box isn't bad.
They don't look too bad on the hard top to boot.
Coming out of cruise and starting to coast, decelerating slowly instead of slamming and dropping in speed felt weird.
I've got 6 AirTabs left that I'm got to play with to see if I can get any more improvement on other body locations.
Hopefully I've covered it well enough, please let me know if I might have left out something relevant.
Thanks
Aerodynamic auto designs, past and present, and their possible implications The Toecutter Automotive News, Articles and Products 12 02-10-2007 12:04 AM
Fuel economy links kickflipjr General Fuel Topics 0 11-27-2005 11:00 AM
