Vortex Generators / Hmmm Airtabs - Fuelly Forums
Old 10-31-2006, 08:17 AM   #10
cfg83's Avatar
FormulaTwo -
Alright well, here we go.....
I decided to reinstall them using 3m tape, like what is used on vent visors etc...
We have plenty of this at my work for me to play around with.
I tried it out on one just to see how high the airtab would actually sit with the 3m tape under it. It did not exactly sit flush, but definitely a good strong hold.
I took electrical tape and taped off the front edges, and part of the sides. This should smooth out airflow onto the airtab, and maybe hold the tab a little better.
So far so good, it looks a little awkward only having 3 tabs installed right in the middle of the rear of the car.
To be installed correctly I will actually need 4 more.
They say to install them 4" from center to center. No more than 10 inches from the rear of the vehicle.
Honestly I do not feel must difference in the car on the highway. I know there have been reports of increased stability etc... Then again there are only 3 up there, which probably wouldn't do too much if these things worked anyway.
I am guessing that you need to start from a crummy aerodynamic place to begin with, like a Semi, in order to feel improvement. Also, the Semi's in the pictures are *covered* with them at the end. The one picture of the Honda CRV might be what you should look to accomplish.
I wonder if you can do a before/after coast test. It will be hard to keep things equal unless you have a "perfect road" to work with. Test must be done with same prevailing wind/temp/humidity conditions.
I may tape some tufts all over the rear of the car this weekend, so I can get an idea of what the air is doing back there.
I will need someone to help with this, maybe video tape- take pictures...
from what i read.....
# Tufts that move around chaotically are a sign of drag.
# Tufts that move in the direction opposite to the airflow are a sign of high drag.
# Tufts that stay in line with the airflow are a sign of lower drag.
anything else to look for?
I will def post pics when i get them
Too bad none of you FE guys are from around here.
Could start up our own backyard FE skunkworks.
I would really appreciate seeing your "Tuft Setup" in order to see how to set that up.
Aerodynamic auto designs, past and present, and their possible implications The Toecutter Automotive News, Articles and Products 12 02-10-2007 12:04 AM
Fuel economy links kickflipjr General Fuel Topics 0 11-27-2005 11:00 AM
