10-30-2006, 01:51 PM
Originally Posted by zpiloto
Your throwing your money at the wrong things. I know there expensive but fix the O2 sensor that will give you a better FE increase (10-15%) then air tab and LLR tires combined not to mention that the environment will thank you to.
Agreed, although the tires i did not have a choice. Considering the ones I had went completely bald due to my crappy alignment. So now the alignment is my #1 priority.
The EGR box I have to go pick up about an hour from here, but havent yet.
The o2 sensor will soon follow. If I see a 10 to 15% increase off of the O2 sensor then I will be amazed. Im pretty sure the car is not going into lean burn since the ECU is seeing the o2 error, and adjusting the fuel for safety.
If any of you guys know of places to get deals on 5 wire o2's, let me know. I am going for NGk most likely, i hear bosch are crap.
Order some golf shoes, otherwise we might never make it out of this place alive.
12-31-2006, 06:32 AM
I had this site saved. You might find what you need here.They have NGK.
http://www.bmotorsports.com/shop/pro...0f0bb2bad73acc
