Tweaking Bosch FI - Fuelly Forums
Old 09-02-2008, 09:34 PM   #1
Tweaking Bosch FI
The search still continues for a car, I have been leaning towards Cavaliers and Saturns due to their ability to go into lean mode by either an HAI or resistor in the IAT circuit. The cars I have looked at have been in bad shape, so looking to alternative cars, I have found a 90's BMW that has the classic Bosch FI that uses the air box barn door MAF. Now my question is; Is there a way I can tweak it to get it into lean mode? Is there an IAT in the system that I can fool to lean the a/f ratio? I have read that the BOSCH system is harder to fool, can I reset the MAF barn door? Or EFIE the O2 sensor.
I know Ford and Mazda use a type of barn door MAF, as well as many other imports. Any ideas?
Old 09-03-2008, 06:12 AM   #2
Usually the clock spring in those AFMs can be adjusted to have the ecu read more or less air. I don't see why that in conjunction with an EFIE wouldn't get that engine to lean out a bit.
- Kyle
Old 09-03-2008, 02:13 PM   #3
Jetta90GL's Avatar
On the ford 2.3L turbo's they were called VAM (Vane Air Meter) i believe. Many people try to tweak to gain power, I think results varied a lot. Here is some info on Thunderbird Turbo Coupe VAM mods:
http://www.turbotbird.com/FAQpage/FAQpage.htm#VAF%20Mod%20for%2088TC:
http://natomessageboard.com/cgi-bin/...=000255#000003
We would want the opposite of course, for less fuel...
Jetta90GL is offline   Reply With Quote
Old 09-03-2008, 03:11 PM   #4
I'd think of trying a plumbing valve in parallel with it for an adjustable bleed.
Old 09-03-2008, 03:32 PM   #5
One way is to tighten the spring, and add a variable resistor in the coolant temp circuit. That way you can make it too lean and use the variable resistor to tweak it.
Whatever you do mark you present tension setting so you can go back to it if things get funky.
On the older Nissans (83 and earlier) there was bypass circuit for adjusting the idle mixture.
We used a vacuum guage to set the mixture, running at about 2500 RPM. Then we would set the idle, with the bypass.
You could play with the variable resistor then measure the resistance under different loads and maybe rig a set of individual resistors for different vacuum readings or throttle switch positions.
regards
gary
Location filter? BDC Fuelly Web Support and Community News 11 09-05-2009 01:16 AM
Leno adds twin turbos and EFI and doubles FE!!! theclencher General Discussion (Off-Topic) 7 12-19-2007 10:52 PM
pulse up or pulse down a hill, higher or lower gear perris Hypermiling 9 07-16-2007 09:33 PM
