Testing Exhaust Systems on my CRX - Fuelly Forums
Old 04-11-2006, 07:27 PM   #1
Well, I've got two exhaust manifolds already, stock and Civic CX/VX/STD/HF.
Jared will gimme his stock D16Z6 header to test, so that's three.
Anyone got any laying around they want tested, or any suggestions in particular for me to do while testing?
I don't mind doing stuff like modifying the one that isn't as good a bit to see if I can improve it, just don't wanna **** up the good one.
Old 04-11-2006, 08:46 PM   #2
Matt Timion's Avatar
I'm glad you're going to do
I'm glad you're going to do this. I might have time to do this myself, but I can't be sure.
If anything we can use it to test the location of hte o2 sensor on fuel economy.
waiting for the supermid might be best though so you can just do a few runs and we can compare the numbers.
Old 04-11-2006, 09:38 PM   #3
Send a message via AIM to molecule
open header should be
open header should be tested
bahahaha !!!
ok how bout...after the cat...???
BE ZEITGEISTED
molecule is offline   Reply With Quote
Old 04-12-2006, 03:14 PM   #4
Right now I'm just going to
Right now I'm just going to be doing headers since I have a few and can borrow a few for free/cheap.
Old 04-14-2006, 07:16 AM   #5
Don't you need a different
Don't you need a different cat for the HF/VX manifold? I thought they're placed in the engine bay compared to under the car for the standard header setup.
Jeff
guvmint_cheese is offline   Reply With Quote
Old 04-14-2006, 07:25 AM   #6
Re: Don't you need a different
Jeff
You're right. On the HF/VX/HX/STD the cat is directly under the exhaust manifold. On the DX/LX/EX/SI the cat is closer to under the engine. HOPEFULLY the cat+downpipe from the VX/HF will bolt right up to where the old cat/downpipe use to be. If it doesn't custom piping will be required.
Old 04-14-2006, 08:12 AM   #7
Yep, i have the cat and
Yep, i have the cat and downpipe for that so there's no issue there,
Old 08-06-2006, 05:53 AM   #8
zpiloto's Avatar
Bump. To go with the current exhaust discussion.
Old 08-06-2006, 12:57 PM   #9
Well, my testing of this swap was plagued by alternator failure so I said screw it, have had the vx exhaust on for a bit and it seems to warm up more quickly/get higher cruising numbers, but that's just bs, no serious testing has taken place. Will be putting the cx head on this week so Iono if I'll be testing anything unless someone finds me something to.
How to change fuel type JayHoe Fuelly Web Support and Community News 3 06-15-2011 12:14 AM
Help...MPG calculator not working djquik1 Fuelly Web Support and Community News 1 10-18-2010 04:57 AM
Honda n600 on the east coast (Virginia) - $750 Matt Timion For Sale 1 06-19-2006 04:34 AM
Transmission choice for best fuel economy Matt Timion General Fuel Topics 6 11-09-2005 08:37 AM
