temp vs mpg - Fuelly Forums
Old 02-06-2007, 02:32 PM   #1
Team OPEC Busters!
GasSavers_Brock's Avatar
temp vs mpg
I have also been very interested in how outside temps affect mpg. I have been collecting data for quite a while, but honestly not sure how to compile it to make since.
Daily I kept track of my mpg, engine temp when done, adv speed, outside temp and if the engine was cold, warm (heated via coolant heater) or hot (as in just ran and is already warmed up.
If someone wants to take a shot with the excel data feel free.
It is at http://www.uwgb.edu/nevermab/mpg.xls
Old 03-18-2007, 12:03 PM   #2
just to make sure your considering this... gas is formulated differently throughout the year depending mostly on weather.. which is a large portion of the reason why your seeing such a decrease in fuel economy in the winter.
thecrxproject is offline   Reply With Quote
Old 03-18-2007, 04:59 PM   #3
Actually, many people overestimate the effects of seasonal gasoline formulations on fuel economy. In fact, most other factors affecting your cold weather fuel consumption play a much larger role than the reduced energy content in "winter gas".
EPA:
typical summer conventional gasolines contain 1.7% more energy than typical winter conventional gasolines.
http://www.epa.gov/otaq/rfgecon.htm
Old 03-18-2007, 08:36 PM   #4
ELF
ELF's Avatar
I'm not sure our gas here in MN changes at all. We used to get ethanol added in winter only, as a oxygenate.(sp?) now we have e-10 year around. I can't tell any difference between summer and winter gas myself.
Old 03-18-2007, 09:35 PM   #5
cfg83's Avatar
ELF -
I think that here in LA there is no reason for them to change the formula at all.
Old 03-18-2007, 09:39 PM   #6
GasSavers_Red's Avatar
We get the change up in NorCal. There is enough ethanol that you can actually smell it
Old 03-19-2007, 08:08 AM   #7
Team OPEC Busters!
I do understand that fuel changes as the temps change. I believe diesel has a wider total BTU change as the fuel changes for winter. I also run snows and often change their pressure between 30 psi and 45 psi depending on weather as well.
But what I am getting at is since I am on the same tank for about 4 weeks I can see a difference as the temps raises and drops, the fuel is the same the whole time so the temps has to be whats causing the change.
Not very precise mpg calculation larjerr Fuelly Web Support and Community News 4 08-20-2012 02:03 AM
Browse Vehicle (I cant find my own vehicle.) deadbanana0717 Fuelly Web Support and Community News 2 09-29-2011 11:19 PM
Keeping my distance in traffic khurt General Fuel Topics 8 09-07-2008 04:23 AM
Car wrecked. Compaq888 General Discussion (Off-Topic) 80 06-15-2006 12:23 AM
