08-07-2009, 04:33 PM
Tape a barometer to your hood? YES!
I'm not sure what to make of this, but I found this web site that sells USB data loggers that record barometric pressure. They taped six to a car, drove around, then later downloaded and graphed the results. They also went over a high bridge so you can see that in the results too. Here's a linkie:
http://www.gcdataconcepts.com/carairflow.html
Thought I'd post it and let the hive-mind ruminate on it. A bit bizarre, but maybe one "could" use this technique to asses effectiveness of grill blocks?
Well, Enjoy!
08-07-2009, 05:02 PM
The price is pretty high. I thought OBDII can report barometric pressure.
08-08-2009, 03:42 PM
OBDI and II can read baro if the airflow sensor has a baro sensor in it. It's used in airflow calculations, which are used to calculate fueling. My car has one, came with it from the factory. I wouldn't want to remove it or place it anywhere else.
Didn't COZX2 use Magnahelic differential pressure gauges to fine tune the aero on his car? I'd think it's a cheaper and effective solution for our needs.
Dave W.
08-09-2009, 05:53 PM
I think you guys miss the point of the post, which was a unique way of of measuring phenomena associated with the aerodynamics of a vehicle. I know OBD can report back pressure, BUT NOT FROM THE HOOD! And yes the price is high, but I still thought it was an unusual method and others would find interesting.
I think I'll go so some other web sites now...
08-09-2009, 08:23 PM
I was contemplating using a bunch of water tubes...
08-10-2009, 03:55 AM
OIC. Yes, I did miss that. That's a whole different ballgame...interesting.
08-10-2009, 10:46 PM
I didn't miss the point, that's why I wrote: "Didn't COZX2 use Magnahelic differential pressure gauges to fine tune the aero on his car? I'd think it's a cheaper and effective solution for our needs."
Sorry I don't have time to search for you, but you'll find plenty of good aero info if you search for posts made by a member named 'COZX2' on this site. BTW the magnahelic differential pressure gauges are air pressure gauges.
Dave W.
