Tail pipe restrictor test - Page 3 - Fuelly Forums
Old 11-11-2007, 04:18 PM   #1
GasSavers_Erik's Avatar
I read the high flow muffler thread and was motivated to start a test last weekend.
I filled my 87 Civic's tank and then I drove a little more than 200 miles this week with a crude mod that decreased the size of the tailpipe opening from 1.5 inches to about the size of a dime. Its actually a steel can that is clamped over the tailpipe with a radiator hose clamp (fuzzy pic is attached).
Mileage for this tank (with the restrictor mod) was 37.45. The last tank was 38.59 mpg.
The A-B B-A part of the test I drove was 120 miles (60 miles between A and B) at 60 mph. The other 80 miles or so were mixed city/highway driving.
The weather was colder this week than last week and I wasn't sure if the previous tank was completely full. I also did no EOC this tank.
Noise- about the same at idle, definitely quieter at 60 mph.
Driveablility- not noticeable around town, a little less power on long steep hills
Other differences- when pulling a long steep hill, I could see the engine temp coming up noticeably even when outside temps were cold. It usually stays within 1/3 and 1/2, on a few hills it went up to maybe 60%. The temp doesn't rise this much without the mod when driving the same hills in warmer weather.
(By the way, I know I was no where close to boiling over. I overheated the engine several months ago and recall that it happens at the edge of the red zone- or at about 95% up the gauge).
I could also tell that the cooling fan was running more even when in city traffic. This makes sense because probably more of the hot exhaust gasses were remaining in the engine.
I plan to test it for a few more tanks before making a judgment. Right now I feel the results are inconclusive as to whether it increased or decreased my mpg.
The next model I build to test this will be a spring loaded exhaust tip that will maintain a certain amount of backpressure regardless of engine load/rpm.
I'll probably take it off tomorrow and do a few tanks without it and then do the improved version.
Too many entries W/ "0 MPG" DPTyphoon Fuelly Web Support and Community News 7 09-13-2008 02:19 AM
Save $$$ on Wood Carving you didn't buy. CO ZX2 General Discussion (Off-Topic) 5 06-03-2007 11:56 AM
WTB 5 wire O2 Sensor GasSavers_Jack For Sale 6 12-01-2006 01:00 AM
Greetings kps Introduce Yourself - New member Welcome 10 09-26-2006 05:15 PM
Ok, you Screw Balls! kozaz General Discussion (Off-Topic) 10 08-23-2006 06:06 PM
