03-26-2006, 12:27 AM
#40
Re: So basically it only
Originally Posted by SVOboy
So basically it only measures those two variables coming from the car and then you preset certain things like injector size and all that?
Yes. The distance and fuel parameter setting will adjust the variables.
Is it tapped into the injector signal lines coming from the ecu or what?
Yes. It is connected one of injector lines for fuel usage.
What method does it use to analyze the pulse width?
It uses the ICP or input capture function of Atmel ATmega8 microprocessor.
What language is the code written on for the chip that controls it?
An assembler of AVR Studio 4 by Atmel.
Yoshi
