SuperMID M1, MPG Computer - Page 8 - Fuelly Forums
Old 03-11-2006, 07:54 AM   #71
krousdb's Avatar
Re: Woot. That's very good, I
Originally Posted by SVOboy
Woot. That's very good, I hope the calibration sticks to being correct and whatnot, now you've got to go update all those trips you went by the MID with.
Doh! Yes, thanks for reminding me. The data do need to be updated so that they are accurate for comparison purposes.
Old 03-23-2006, 03:17 PM   #72
krousdb's Avatar
SuperMID Update
Tonight I added 10.042 gallons, which is what the SuperMID showed. The digital fuel gauge showed 2.5 OHMS which is where I filled it to last time. Since the 2.5 mark is the lowest that the gauge shows, there is a chance that it hit 2.5 OHMS before I got to 10.042 gallons so SuperMID probably isn't perfect dead on as the data might indicate. But it is pretty darn close.
- Miles Indicated (SuperMID) 571.8
- Gallons Indicated (SuperMID) 10.042
- MPG (SuperMID) 56.94
Not a bad tank, eh? Ave driving temp 30-35F. Can't wait for sustained warmer temps.
Old 03-23-2006, 04:04 PM   #73
glad the supermid is working
glad the supermid is working out. question: what does its name mean?
and nice driving, krousdb! i like the way your gaslog is "trending".
the warm spell we had a week or so ago was a nice tease, wasn't it? i can't wait for some more of that.
Old 03-23-2006, 04:19 PM   #74
krousdb's Avatar
I have no idea what the name
I have no idea what the name SuperMID means???
Yes the trend is nice. The first few days were in the 50'sF and I scored a few RT commutes at just over 60MPG. I had high hopes for this tank but then the teens and 20's came back for the AM trip and 20's and 30's for the PM trip. I was lucky to end up where I did. Once we get some warm temps back here in PA I promise to send it up North if you promise not to send any of your Canadian air down here.
Old 03-23-2006, 04:42 PM   #75
Re: I have no idea what the name
deal!
besides, now that i've wrapped up nearly a week of afternoons on my back on the garage floor in 1 C temps, i'm sure it's bound to warm up anyway.
Old 03-25-2006, 06:24 PM   #76
Re: glad the supermid is working
Hi all,
The MID stands for Multi Information Display.
I wanted to add something to that.
So, decided to call it SuperMID.
Yoshi
GasSavers_Yoshi is offline   Reply With Quote
Old 03-25-2006, 08:58 PM   #77
Re: Hey yoshi, could you give me
Hey yoshi, could you give me a rundown of all the parameters that the SuperMID monitors? I've been wondering about this recently. Thanks a ton.
Hi SVOboy,
input:
- injector pulse width
- speed pulse for distance
output:
- line1: instantaneous mileage, instantaneous fuel usage, injector pulse width
- line2: 1km avg mileage, timer(blinks every 5min), avg speed
- line 3: avg mileage, driving time, distance
- line 4: engin-on mileage, engine-on %, cannel name, fuel used.
- 5 channels are T(tank), A(trip-A), B(trip-B), L(lap - max 20 laps) and S(start - since power-on)
Please refer to following diplay menu...
http://img223.imageshack.us/img223/1883/m1menueng7of.jpg
Yoshi
Old 03-26-2006, 12:27 AM   #78
Re: So basically it only
So basically it only measures those two variables coming from the car and then you preset certain things like injector size and all that?
Yes. The distance and fuel parameter setting will adjust the variables.
Is it tapped into the injector signal lines coming from the ecu or what?
Yes. It is connected one of injector lines for fuel usage.
What method does it use to analyze the pulse width?
It uses the ICP or input capture function of Atmel ATmega8 microprocessor.
What language is the code written on for the chip that controls it?
An assembler of AVR Studio 4 by Atmel.
Yoshi
Old 11-29-2007, 03:13 PM   #79
Originally Posted by Yoshi View Post
It measures the pulse width of injector for the fuel usage.
If the vehicle goes to the fuel cut mode, the pulse width becomes zero.
Basically, the SuperMID M-1 works on any car which has fuel injectors and speed(distance) pulse output.
Do you know the pins for these signals from your ECU?
Yoshi
I am trying to figure my fuel consumption on an 1984 AMC Eagle.
My engine is an AMC258 Inline 6 carbureted, My question can I use your SuperMID device or am I still in the dark?
Thank you
Jeremy
GasSavers_ZiLg0 is offline   Reply With Quote
Old 11-29-2007, 04:39 PM   #80
ajohnmeyer's Avatar
Send a message via AIM to ajohnmeyer
Sorry, it won't work in your AMC. the Super MID only works in cars with electronic Fuel injection, and more specifically, only with the Toyota Prius and certain Honda 4cyls.
You could try using a vacuum gauge in your AMC though
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." -The Drive By Truckers
Team OPEC Busters!
ajohnmeyer is offline   Reply With Quote
Mileage/KM Missing from 1 Fill Up. mechjames Fuelly Web Support and Community News 5 03-09-2010 03:17 AM
