Supermid M1 install in 88-91 crx - Page 2 - Fuelly Forums
Old 09-19-2007, 01:21 PM   #11
Bunger's Avatar
From what I have read, the M1 isn't setup to work with a 2 injector TBI system (which is what the DPFI pretty much is). So you would need to convert to MPFI, which can be done by swapping distributor, ECU, and intake manifold + tb, and some wiring. I've done a number of these conversions myself, but if you don't at least feel comfortable doing things like changing your oil or installing a car radio, I wouldn't suggest you attempt this conversion.
The write up above is good, but I should add that all the connections you needed were right at the ECU: constant power, ground, VSS and an injector.
Anger is a gift!
- Zack de la Rocha
Old 10-02-2007, 07:34 PM   #12
hey Daniel,
So it looks like installing a Super MID should be fairly straightforward on a 1991 CRX HF then as well? I don't know much about electronics at all, so I would pretty much just be following your DIY.
Also, do you feel being able to watch your FE all the time improves your FE?
McPatrick is offline   Reply With Quote
Old 02-02-2008, 09:03 AM   #13
guest001's Avatar
where can you buy this??
sorry....
nevermind, I found it.
guest001 is offline   Reply With Quote
Old 03-09-2008, 05:56 PM   #14
Installed mine today in '88 CRX HF CA model. T tap connectors Pin A1 at ECU Brown (white connector top front wire brown on mine some are different color) for injector signal. Pin B16 (red/yellow on middle black connector) for speed sensor. Red to radio hot. GND to ground
FritzR is offline   Reply With Quote
More lists? skinnious General Fuel Topics 4 12-08-2010 12:12 AM
The great news about the EPA's new tests repete86 General Fuel Topics 8 02-07-2007 07:01 AM
Greetings kps Introduce Yourself - New member Welcome 10 09-26-2006 06:15 PM
E-85 and EPA rating zpiloto General Discussion (Off-Topic) 7 09-26-2006 07:04 AM
1995+ Metro Front Brakes 95metro Experiments, Modifications and DIY 15 07-04-2006 03:12 PM
