Well the deed os done. It was a lot of work for 30 minutes of grooving. I am not a fast mechanic. I have heard that one can remove the head on a DOHC Saturn wihout pulling the timing chaning cover. There was no way it was going to happen on the SOHC engine. Darn there are a lot of bolts on the accessories and the body and right side (front) of the engine are closer than I would prefer. Here are a couple pics.
As soon as I got the head off I was a bit dissappointed. The squish area was not as large as I had expected based on other pictures I had seen on the internet. Also the piston is slightly dished. The flat face on the piston is only about a 3/8 inch ring on the outside. Also one of the valve reliefs intersects the groove in the head. It had what appeared to me a lot going against it. Also the combusion chambers alaready have an appearance similar to the Brings and stratton post grooves. I decided it would be foolish to do all this work and not put in grooves so I put in grooves. I intended to use a 1/8 inch ball bit and go 1/16 inch deep. When I got set up all I had was a 3/16 inch ball bit so I only went .040 inches deep. The router attachment on the dremmel worked pretty good. I bobbled on one groove.
I was sorely tempted to decarbon the valves and other things but all I did was do the grooves. Nothing more. Oh for the sake of completeness I should say I dropped a spark plug and had to replace it with same make, same number, same gap.
I should not discuss this yet but I would be curious if I were you. This is based on a scangauge that is calibrated a bit conservative but was calibrated at slower speeds doing pulse and glide. I reserve the right to correct this data as time passes. The fuel gauge is matching the scangauge quite well at this point.
I just got it together last evening. I drove 150 miles last night and this morning just for the heck of it. At 60 mpg that's cheaper entertainment than some movies
. Naturally we all want to know if it made a difference. The Saturn already ran pretty good. So far by the scan gauge I more than exceeded my expectations. It has a slight bit more torque so that when I tried P&G on my usual route I over accelerated a bit or achieved my desired speeds a bit sooner than expected. This is a subtle impression and not readily quantifiable.
Okay, I ran 3 loops on the freeway at average speeds of 60 mph. That was three runs west and three runs east. The temps ran 80 -95 deg F. There was a 5-10 mph breeze against me on part of one east run. It switched to a light cross wind. There is a construction zone at 55 mph but I made up for it. Otherwise I drove constant speed trying to avoid drafts from the moderate traffic. I did not include the acceleration and coast which would constitute a P&G cycled even though the legs are 14 miles long. It is pretty easy to roll up 1-2 mpg coasting off the freeway. The water temp ran 196-235 deg F. The IAT ran 180-200 deg F.
Actually on one west bound stretch I had to stop and pull some grill block as I had removed the fuse for the cooling fan and it got up over 235 deg. F. I did include that stop and start. That stop and start hurt my average a bit as I was on a freeway and traffic cramped my style. I pulled too much block and cooled off too much. Yeah, I could use some shutters. Incidently while 220 is very good at 238 WT the car seemed to start losing mileage. I did not go long at those temps.
east 56 mpg
west 72 mpg
east 57 mpg
west 69 mpg
east 57 mpg
west 70 mpg
This averages to 63.5 mpg. The very best I have done on this loop before was 58 mpg. I did not consider that singular event valid enough to claim that mileage. I had confidently claimed 56 mpg on this loop before the grooves. I'll split the difference for 57 mpg pre groove. Using 57 mpg as the base this is an 11.4% improvement.
I then did a 70-75 mph shorter run that will lack accuracy. Actaully the scangauge had me at a max of 79 mph. I was just going faster than 70 to get an idea of 70 mph mileage. These were just 4 mile runs.
west 60 mpg
east 50 mpg
average 55 mpg.
Today the total was 96.7 miles, 60.2 mpg 48 mph ave.
Yesterday 53.8 miles, 60.2 mpg, 40 mph ave.
I knocked a bit off my tank average. Sorry leftover bananas. It's the price one has to pay for knowledge sometimes.
I consider my 60 mpg at 60 mph goal accomplished unless I come up against another scangage fluke. I will certainly keep you posted.
I still have the the LC1 wideband O2 sensor in the box. Gee when does a guy get to stop
? There is a lot of drag at 70 mph too.
