12-18-2005, 07:38 PM
Solar/plug-in 12V system, alternator optional
hi all. my first post. i'm pretty impressed with the signal/noise on this site. good work.
here's an idea to mull over. pardon me while i think out loud...
i read recently about a guy who removed the alternator from his vw bus, installed pv solar panels on the roof and a couple of deep cycle (marine/RV) batteries on-board. The output of the panels and the extra storage capacity of the deep cycle cells kept the sytem working fine, even at night - he drove round trip from texas to seattle on this set up.
how much fuel would it save if an engine didn't have to turn the alternator? depends on how much power the alternator is supplying and the parasitic losses needed to supply it.
if i had to guess, i'd predict savings between 1 to 5% - but that guess is based on a series of assumptions so unfounded, i'm not even going to bother sharing them here. maybe someone else is more informed on this topic and can accurately predict (if so, please share).
other options...
<ul><li>leave the alternator on, but add a switch in the rotor field control wire, effectively giving YOU control over when the alternator is active (from an efficiency standpoint, it's best "ON" when you're decelerating or descending a grade - the same times regeneration is active in hybrids)<\li>
<li>same setup as above, but only use the alterator switch as a back-up for long range trips. for short-range use, re-charge the battery with a charger in the evening. (you can tell your neighbours you've got one of the first plug-in hybrids.) or recharge with solar when you're parked.</li>
<li>even more efficient: take the alternator belt completely off (there are still parasitic losses (bearing/pulley fan) in options 1 & 2). again, recharge when only when necessary via solar/dc charger. downside: less convenient when you need the alternator for long-range trips or "emergency" charging</li>
<li>buy 2 batteries and charge one (trickle/solar) at home during the day, then swap batteries each evening or as required</li></ul>
just a note: deep-cycle type batteries (RV/marine) would be a necessary part of this approach. a regular automotive battery will be damaged/degraded from a significant discharge.
anyone with a scangauge want to do a quick'n'dirty run to give an idea of potential savings? "normal" vs. belt on/alternator disconnected vs. belt completely off?
i've got a scangauge, and would do it, but don't have a heated garage. winter has truly arrived here in ontario, with the result that further efficiency mods are on hold until the spring!
darin
www.MetroMPG.com
12-18-2005, 08:16 PM
I think they best setup
I think they best setup would be to get a low amp alternator (these can be custom ordered for place theat sell high amp alternators for audio system). A race battery will save around 25 lbs too.
This is a race type setup and would be very efficient, But It wouldn't work good in the winter. And I would be very nerous with this setup (i don't know if it would work in a rain storm with the high beams on). Gains would be minimal.
this who post is sorta off topic from the original post...
2008 EPA adjusted:
12-19-2005, 03:55 PM
Re: Solar/plug-in 12V system, alternator optional
i read recently about a guy who removed the alternator from his vw bus [snip]...
darin
www.MetroMPG.com
Welcome and good site as well. This idea brings up something that I hadn't thought of. A popular add-on to make more horsepower are "underdrive" pulleys that make the belt-driven items turn more slowly, and reduces parsitic loss.
I like your idea of removing the alternator from the equation, especially for short hauls. I'm not sure how much fuel savings can be realized, and if you add batteries, that's extra weight.
Does anyone have underdrive pullies installed?
12-19-2005, 04:14 PM
Think you missed the
Think you missed the underdrive pulley thread on the general area.
12-19-2005, 04:28 PM
Re: Think you missed the
Crap, I've committed the Cardinal sin of posting. Sorry... :-(
How did I miss that thread -- I'm slipping.
12-19-2005, 04:53 PM
Haha, posting is good, wish
Haha, posting is good, wish I had some time to.
12-19-2005, 05:57 PM
thanks.
i wasn't going to say anything about the cross-posting
03-30-2006, 09:21 PM
I compleatly lost the
I compleatly lost the information on it, but a few years back I saw a product that replaced your alternator with a perminent magent motor/generator that monitored you battery, to run free when not needed, charge the battery when needed, and had an extra deep cycle battery I belive that it drew from when you needed more power... basicly a bolt on hybrid drive... yes slightly off topic I know.
solar charging your battery so you could remove your alternator is a fine idea, but not one that I would put out to the world at large, to many people have cars that never see sun, pull out of the garage early in the morning, park in a parking ramp, drive back in the evening.
09-20-2006, 04:44 PM
I had a $45 dollar hawker battery for a while, it weighed in at 9lbs I believe, It worked fine for me even in the winter (-20 f.) I forgot the lights on one day, it quickly went dead and would no longer hold a charge. I couldn't locate the battery again, otherwise I'd buy it again.
BTW I think that dyna-batt is actually a higher priced Hawker, just with a different sticker on it. Rumor has it they dont' last as long because the sticker is also the vent cover. The Hawker one was supposedly better sealed compared to the recovered Dyna-Batt. I read this all many years ago, so things could be wrong or changed by now [/disclamer]
09-20-2006, 05:37 PM
I've been thinking about alternator drag due to electrical use as well. The idea has merit, and it might save you more FE than you realize. However, the very first thing I would do (and did do in my CRX) is to convert many of the lights to LEDs, to greatly lower power usage. This will help (by allowing the alternator to work less hard, and thereby put less drag on the engine) even if you don't do anything fancy with the alternator setup.
See this thread for some ideas on LEDs:
http://www.gassavers.org/showthread.php?t=1558
I think you are underestimating the loss due to the alternator. Follow the links in this thread for more info:
http://www.gassavers.org/showthread.php?t=1798
Yes, you would always be paying the price of the "no load" alternator drag with this setup.
However, it would be easy/trivial (even when driving down the road) to switch between "no load" alternator and full alternator drag. So it is "friendly" to the driver (especially when you find yourself on a long trip, and need that extra power)!
Some other thoughts:
1) If you want to get fancy, rig up an electronic relay setup, to engage the alternator when you want "regenerative breaking" (you could still have the "always on" override switch, for long trips). The easiest (but not quite the most useful) way to do this, is to have the alternator engage the same time the break lights come on (and the car is in gear, as it does no good to engage the alternator when the car is in neutral and/or the clutch is in). This will give you the extra "regenerative breaking" drag when you step on the brakes!
2) I'm not sure if you would need some voltage regulator to use them in a car setup, but you can get reasonably powerful solar panels designed for solar power in a home. And while they still cost a bit (about $80 for the cheapest ones, and closer to $300-$400 for a few amp unit), they are much cheaper per watt of power than many smaller panel setups. Even one of these panels could (on bright days) get you a few amps of power for your car. As just one example of what is out there, perhaps the panels sold by "Backwoods Solar" (a company catering to homeowners whose home is off the main power grid), could be easily adapted for use in a car:
http://www.backwoodssolar.com/Catalogpages2/solar2.htm
Yes, that would avoid the drag of the alternator at no load. However, it is a PITA when you need the alternator power.
If you were going to take that approach, I would recommend wiring things in with the switch setup (discussed above), and then only remove the belt when you are reasonably certain you won't need the alternator for a while (and when you do remove the belt, keep it in the trunk). That way you can "easily" revert to the more flexible "switched setup" (when needed) by just popping the hood and putting the belt back on...
NOTE: With the belt off, you will not get the "no load" losses from the alternator. But you also will not have any option for "regenerative braking".
Agreed. You would want to replace the normal car battery with something designed for "deep cycle" (and hopefully with more amp-hours than the normal car battery as well).
Sorry, don't have a scanguage.
