Originally Posted by VetteOwner
hmm yea is it the VW?
Yeah, 2000 Cabrio, based on the Golf A3 platform. I researched it over the weekend and it turns out this is a pretty common failure... lots about it on the various VW forums.
...it could... be the computer being weird.
That's exactly it, but not the computer you're thinking of! The instrument cluster has its own little computer that apparently sits on the OBD II bus... think of it as an in-build mini-Scangauge, I guess.
It runs a self-test at engine start-up, and if anything fails it shuts down both the speedo and tach drivers.
I found a guy who had the problem himself and fixed his cluster, then started doing it for Internet friends, then finally started doing it for anyone willing to pay a nominal fee. He says there's tons of capacitors on the cluster boards and most of the time one of those has gone bad, otherwise it's a cracked solder connection, very rarely a bad stepper motor for one of the gauges.
I chose to ignore the "disconnect the negative terminal of the battery" part of the instructions and instead just work very carefully.
Managed to pull the cluster without destroying anything obvious, and it's even now on its way to the repair guy.
The only odd thing I noticed this morning (other than a gaping hole in my dash, haha) is that my SG wouldn't register MPH (and thus MPG) -- I guess when I unplugged the cluster I must have thrown some pretty nasty trash on the OBD lines and confused it or something. Unplugging and quickly reconnecting the SG caused it to reinitialize and start working right (and without losing my MPG figures, yay!)
So it looks like I might have dodged this bullet. I'll have to use my GPSr for mileage readings since my odo is on the way to Canada as we speak
but everything else in the cluster I can get from the SG.
Thus, the V-Power test continues...
Rick
