Running an engine on nothing but vapor (video) - Fuelly Forums
Old 04-06-2010, 06:53 PM   #1
After a bit of playing around, I now have my lawn mower running on straight gasoline vapors!! I'm still tweeking everything to get combustion temps down but if it works good then the next step would be to try it on a car.
http://s8.photobucket.com/albums/a11...nt=Dave009.flv
Old 04-06-2010, 08:02 PM   #2
Lean Burn Mode
pgfpro's Avatar
Cool deal!!!
Have you done a fuel consumption test... carburetor verses your system?
Old 04-06-2010, 08:25 PM   #3
niiice
yea i wonder how much different this can same fuel consumption.
one thing: it may run on fumes BUT can it still cut grass? when an engine like that goes under a load it richens the mix to give more torque
Old 04-06-2010, 08:43 PM   #4
Lean Burn Mode
pgfpro's Avatar
It would be also interesting to see a wide-band O2 sensor (like a Innovate hand held unit with a car battery for power to the unit through a cigarette lighter plug in) on it to see what the A/F is?
Old 04-06-2010, 09:06 PM   #5
Banned
great ive been wanting to build one of these for quite some time, my only issue is vapor volatility in your bubbler, maybe a shut off valve?
on a car this would connect right to the air intake, what happens with the injectors then?, and how do you control fuel air ratio? will it burn lean? and if it does, will lean burning vapor produce extra heat like a lean burning engine?(am i right about that last part?)
Old 04-07-2010, 04:45 AM   #6
I have taken it across some grass real quick and it had no problem cutting and it didn't show any signs of bogging down. I am concerned about the possibility of the combustion temps being too high so I'm currently working on an EGR system for it. Once I have it on and working I'll be mowing my whole yard (about 5,000 square foot). Once I have it running good I'm going to do some fuel usage tests to see how much more or less fuel it is burning.
I'm in the process of trying to track down a portable emmissions tester so I can see what it's emmissions are compared to stock(I can return it back to stock in about 10 minutes). That's a good idea about the wideband. I'll see about putting a wideband bung in the exhaust to see what the air/fuel ratio is.
Old 04-07-2010, 06:53 AM   #7
Banned
well as far as i know vapor gasoline is 10X as powerful, but you use alot less of it, this process might rewrite the rules of running lean ect, such a state may not even exist with vapor fuel, although i might be wrong, there is just little out there about it, so I'd say this is still guesswork
Old 04-07-2010, 01:33 PM   #8
I will be interested in how the fuel continues to burn as the tank gets lower. I hear that the "new" gas does not completely evaporate and you may end up with the tank half full of non-evaporating heavy fuel. Very impressive setup however and it is amazing that it runs that well with no carburator.
Old 04-07-2010, 02:14 PM   #9
lol when u first started it it sounded like one of our old pushmowers that the carb would stick and cause extremely high revs haha i always swore it was gonna throw the rod outa the block...
Old 04-07-2010, 04:09 PM   #10
I started it with the fuel valve wide open, then promptly turned it down a bit.
I think I've got parts gathered up to install an EGR system on it. If it works ok then I'll try mowing with it this afternoon since grass is growing quick now.
Family Carpooling BumblingB General Discussion (Off-Topic) 2 06-07-2008 01:37 PM
34 MPG Grand Prix? adamsjd1 General Fuel Topics 15 05-22-2008 03:36 PM
Real time mpg readout with pre OBD2 Nissans.. fumesucker General Fuel Topics 0 05-11-2008 01:16 PM
Test AnthrAxNSB Fuelly Web Support and Community News 0 12-08-2007 07:53 PM
A RAV4 to go with the Prius? krousdb General Discussion (Off-Topic) 31 12-30-2006 05:32 AM
