Restoring a vx - Page 7 - Fuelly Forums
Old 12-01-2010, 01:27 PM   #61
add|ct's Avatar
Re: Restoring a vx
Epic thread!!! You're an inspiration to us all! Clean car FTW!
'92 Civic VX, Canadian model
Old 12-02-2010, 09:58 PM   #62
Re: Restoring a vx
Thanks for the props. It's very satisfying to make some decent progress. Didn't get quite as far as I'd hoped over the last couple days, but progress has been made. Did a final clean up of the floor pans prior to the carpet going in. The carpet that came used a fairly decent mold, but no cut outs were present in the piece at all. This makes fitting a challenge and time consuming. Here are the final pans
Passenger side: It's hard to see, but there was a porous area just under the ecu connector and I used a bit of fiberglass mat topcoated with por15 to seal it up. It's a great technique I took from the store that sold me the product.
Driver's side got topcoated black and seam sealed
Passenger rear was stripped in any areas with bubbling and coated. You can see an area I've used seam sealer. The 99-00 si front seats don't quite match to the 92 bolt holes for this one mount only. The way I solved this was to drill through both sections of the frame rail, use a nutsert in the bottom rail and run a spacer tube to the pan. It was welded in place and ground down.
Driver's rear was pretty clean except for a little strip which was coated. same technique for the mount here. Both the factory holes were plugged with seam sealer to prevent the ingress of moisture.
Here's how far I got on the carpet installation. Pretty far for a few hours in the darn cold.
Peeking into the quarter panel hole you can see where the area was also treated with por15. I coated everything I could reach inside both sides.
I exit lean burn when my life is at risk.
1998 Odyssey 24.1 mpg average
1984 crx project now on the road
hondaguy72 is offline   Reply With Quote
Old 12-15-2010, 12:56 PM   #63
Re: Restoring a vx
More pictures to come soon. My order from majestic came in with some odds and ends that were needed. The carpet is still under construction, but the rest of the interior is in. I've added a pioneer stereo system with pioneer speakers and new oem antenna. I've polished out any scratches in the interior plastics as well. The only items to finish are a new set of locks for the doors and hatch and the driver's side rocker needs to be stripped and por15 treated. I plan on having everything completed in a week or so.
Old 03-22-2011, 07:10 AM   #64
Re: Restoring a vx
My time lines are always way off. As of now I'm just finishing up the interior carpeting. The full interior is now back in the car minus the front seats and it really looks nice. I'm just about ready to move on to the next project, so check out the FS section as once this is fully completed it will be for sale.
Old 03-22-2011, 10:12 AM   #65
GasSavers_TomO's Avatar
Re: Restoring a vx
Oh man, I wish I had the time/money to put into my VX like yours. too bad I just can't trade my VX for yours
Honda Civic VX Info/Links
Old 03-22-2011, 04:59 PM   #66
Re: Restoring a vx
i need to do this to my chevette, gotta order new carpet first....then get the outer quarter pannel fixed, then painted, haha
Old 04-19-2011, 09:40 AM   #67
dalybrandon's Avatar
Re: Restoring a vx
This car is looking amazing! I'd buy if I could, but I don't need another car... I'm a little far away too!
dalybrandon is offline   Reply With Quote
Old 05-14-2011, 01:00 PM   #68
Re: Restoring a vx
Well, this chapter is about to end. The sale is arranged and should be final in the somewhat near future. Here are some final pictures of the car.
http://s187.photobucket.com/albums/x...20restoration/
I did a very short test of mpg over 115 miles, about 70% highway and included 10 minutes of idling after the timing belt service was complete. Result, 41.07 mpg. Considering no hipermiling techniques and quite a bit of idle time, I would say the car will get in the mid 40's all the time and around 50mpg highway.
Old 06-15-2011, 09:59 AM   #69
Re: Restoring a vx
Nicely done sir! The only thing I wouldn't have done is the Si seats. They are the least favorite part of my EM1.
GasSavers_Sancho is offline   Reply With Quote
Better gas mileage for an RV 73challenger General Fuel Topics 5 10-31-2007 04:08 AM
Hello All GasSavers_MikeD Introduce Yourself - New member Welcome 3 07-23-2007 10:34 PM
Blast from the past: Mobilegas Economy Runs? Spule 4 General Fuel Topics 8 11-20-2006 07:47 PM
