Originally Posted by omgwtfbyobbq
Well, the problem with a small engine is BSFC usually isn't much better than what you're getting anyway.
Anyway, you probably already know this stuff, but I might as well be thorough. The best bet for you depends on what you can do and what your routes are like.
Well, not all of it. I have experience as a mechanic and schooling in engineering but I really had not looked up any specifics on bsfc with respect to small engines and part throttle bsfc. I appreciate your input and you apparently have spent a lot more time thinking about this problem than me.
With respect to regen the only practical reasonably priced small system I found was the brushless etek with the millipack.
http://www.thunderstruck-ev.com/marskit.htm
http://www.sevcon.com/pages/millipakPMAC.html However it is limited to 48 volts.
If you want higher voltage and regen the options are relatively expensive AC or parallel field DC motors with a little lower efficiency.
I had about talked myself into 72 volts to pull a little less amperage from the batteries and therby extend the range. The motor of choice would be a permanent magnet motor so the fields would not be powered. Nothing wrong with a series motor but the PEMG 132 seemed a bit more efficient, way lighter and sort of priced right to me. No regen though.
http://www.enigmaindustries.com/PMG_132/PMG_132.htm
If I were to decide to do this today it would be one of these to motors. There may be other options.
usegeo
